First post, by zwrr
- Member
I got an ATC-2475 card, its 2D works fine, but the 3D has no textures. I re-soldered the FJR and TMU chips on the card, checked for loose pins, and then I tried re-soldering all the chips on the card, ensuring that there were no loose or damaged capacitors, but the problem remains unresolved.I hope to get your help.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
