Good modern PSU for S370
First post, by stealthjoe
Recently, I had been having a bad time with a few S370 boards. In one board with a Via C3, the pwm IC (voltage regulator) died. I tested this board a few times earlier with a Gigabyte P450B and it was fine. Then one day I used another PSU - EVGA 450BR. The board didn't start. I am thinking if the PSU might have shorted the IC.
In another scenario, I used the Gigabyte P450B with another S370 board (Aopen Ax3S). This time the board didn't boot up ever. The seller tested at his end prior shipping it to me with a local brand PSU (not 80 plus bronze certified) and it was working.
For P450B, the max current on +5V rail is 15A. In the case of 450BR, it is 20A. I have used the above PSUs on a couple of other boards (slot 1 with P2/P3, other socket S370 boards, socket A with Duron) with no issues.
In my place, there are a few local PSU brands which have nearly 40A on the +5V rail. However they are not 80 plus bronze and the quality is questionable.
Now it brings me to the question whether both the incidents could be related to the PSU or is it just cases of bad luck with normal wear? Also any recommendations for a good PSU for S370 if the above don't cut it?
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 6, by Archer57
Max 5v current alone does not tell whole story. Most inexpensive power supplies are group regulated and are intended for certain combination of 5v and 12v load. If you load such PSU with 5v primarily, even if rated 5v current is high, voltages may drift (5v goes down, 12v up) and it may either shut down to prevent damage or it may just continue outputting way out of spec voltages.
S370 does not require a lot of power. Look for DC-DC based power supply (basically 12v PSU + 12V->5V DC-DC converter for 5V) with decent 5V rating, around 15-20A are common and would be sufficient for S370. In this case atypical load, like mostly 5V would not matter and there should be no issues as long as you stay within limits in terms of current.
You'll have to dig up which one is which in reviews and such (And it can be a pain), as manufacturers usually do not tell this in specs.
Also do not bother about whole 80+ thing. It only affects efficiency and has absolutely nothing to do with quality or reliability. So choosing PSU with higher efficiency you are saving a few watts of power, especially in case of stuff like s370 which has pretty low power consumption. And that's it - no other benefits.
As for failures... could be anything. May be PSU did something bad, may be the controller just decided to die. It happens.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 6, by stealthjoe
Archer57 wrote on 2025-06-13, 04:19:
The P450B is indeed a single 12V rail PSU. Not sure about the other one. I usually connect only the bare minimum peripherals such as a PS2 mouse/kb. For hard disk I always use a sd to ide converter. So is there any other way to know if the load is properly distributed?
Any suggestions for such types of power supplies?
Reply 3 of 6, by darry
This thread discusses tbe subject matter.
I need help with picking a psu for my Pentium 3 build?
If you do decide to try a modern PSU, always check actual specs of the specific unit you are buying. PSU manufacturers love to introduce silent (or nearly so) revisions of their models. Newer revisions of a given model may have lower capacity 5V and 3.3V rails than older ones, even high end units with DC-DC converters in those secondary rails.
Reply 4 of 6, by DEAT
Socket 370 CPUs use +12V (and not an awful lot of it), so pretty much any contemporary PSU will be fine. I've even used 80W picoPSUs such as https://mini-box.com.au/product/picopsu-80-wi-32v/ without too much trouble, as long as the video card isn't too demanding with +5V. A 1.4Ghz Tualatin will stress it a bit, though reducing the FSB down to 100Mhz or 66Mhz is perfectly fine.
win16.page | Twitch
Reply 5 of 6, by shevalier
DEAT wrote on 2025-06-13, 07:13:
yep
50mA to PWM controller + 50mA to COMport.
Well, the fan also consumes 150 mA.
the video card
FX5700 is fully powered by +3.3V
All 30+Watts.
Radeon 9600 - almost the same. (not counting 2-3W for memory buffers.
Why? - well, that's how they did it back then)
9800 - 80% to 5+3.3V
https://github.com/TeHSiGGi/agp-power-monitor … RENCE_VALUES.md
Well, Tualatin itself - (30+ Watts) + (losses due to the efficiency of the VRM) from +5V rail.
Chipset+RAM - ~25W from +3.3V
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 6, by darry
shevalier wrote on 2025-06-13, 09:07:
yep 50mA to PWM controller + 50mA to COMport. Well, the fan also consumes 150 mA. […]
yep
the video card
All 30+Watts.
Nice! I had been looking for that kind of info a while back. Thank you.
EDIT: This tbe thread from that time. Question about Geforce FX 5900 current draw per rail
On the whole system power consumption front, here is the data I got from my Tualatin 1400MHz system at the time. Re: What modern PSU powers your Pentium3 setups? EDIT: This whole thread might be interesting too.
