First post, by CraZyP
Does anyone know of any software that could share an iso similar to the way that cdrom servers shared cdroms back in the day. I’m surprised that I can’t find anything online. This could maybe be helpful on systems that can’t natively mount iso files like dos.
Reply 1 of 2, by zuldan
To access ISO’s across the network in DOS, I use NETDRIVE (https://www.brutman.com/mTCP/mTCP_NetDrive.html) to connect to a network drive then use SHSUCDHD + SHSUCDX (http://adoxa.altervista.org/shsucdx/index.html) to mount the ISO.
Reply 2 of 2, by wierd_w
Uhm.... I have mounted .iso images off my nas' share and used them with image mounting software for years?
If you want to have a cdrom's filesystem exposed, a linux based NAS is still the best option here, since that system can mount the .iso using the loopback device, then just share the resulting filesystem as a share.
Similar can be done with windows, if you really want, just not as leanly/cleanly.
