First post, by Darkcrafter07
Duke07 is perhaps my source port of Duke Nukem 3D for MS-DOS.
I came up with an idea to make this port accidentally after messing around original Duke Nukem 3D source code.
I'm a beginner at coding and after some more or less "successful" attempts to modify the original engine I realized it could be stacked all together.
I can't promise to work consistently on it as it's a hobby project. If that could help some people to have some fun - why not publish it?
Put Duke07.exe in a folder with Duke Nukem 3D Atomic Edition v1.4 or v1.5 is installed.
You may run it with a flag /nofpu like "Duke3D.exe /nofpu" to speed up rendering on
reall old and slow 386/486SX CPUs withot FPUs.
Features at the moment:
- y-sky parallax shearing based on player's look up/down and slopes if mouse aims off.
Player's height relative to the world is also tracked. Integer math only version turned on by default as floats are useless but the code without integer optimization is commented and included.
Must be done really wrong and is not very smooth.
- /nofpu command line parameter to speed up rendering on really old and slow 486 or even 386 CPUs without FPU.
At this moment I couldn't implement anything better than interleaved ticker dependent scanline alternation. In engine.c, basically only grouscan and drawalls functions are modified to handle different rendering paths. I can't modify this thing any further at the moment unfortunately.
- playanm function enhanced and now correctly removes played ANM files from the RAM (cache) via "suckcache(anim_t_internal);" command. Turns out, original Duke didn't do that at all because "free animation" command referenced to the one defined in animlib.c and it was commented out (disabled) for a good reason - it used John Carmack's zone.c hidden in "mact386.lib" memory handler which isn't compatible with Duke3D's cache1d.c system. All sounds are now stopped after animation is played.
- playanm_split function is present in the code, tested but unused. Can be used to split a large ANM file and play in one go, one after another and skipped by pressing Enter, Space or Escape just once. Messes up the palette a little-bit after the first animation was played. Unloads a played ANM file from RAM (cache) before playing another one in the sequence. Useful to play large anm files with as much lower RAM consumption as possible.
- animlib modifications to untie it from "mact386.lib" stuff with the same namespace. "_internal" suffix added to each of the functions.
- correct stop all sounds after a bonus screen ( finish level screen ).
Reply 1 of 8, by MrFlibble
That's charming, I'd love to see this being developed further!
Have you looked at the restored code for various versions of the game? Maybe there's some interesting stuff there too.
Very nice that you enabled a no-FPU mode. Have you actually tested this on a 386? I think that official releases of Duke3D never supported 386s as an architecture. Would be neat if you could make something along the lines of FastDoom eventually.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 2 of 8, by Darkcrafter07
Thanks, glad somebody finds it useful
It's pretty nice that there's lot of source code present on the web.
I also liked FastDoom projects as it's something that allows to get more out of less and here's where my interest grows from basically. There's also Doom8088 and RealDoom that I once ranted about how bad they were, it's incredible to see how the games can be optimized, not my level though yet.
There's a feature I liked so much about FastDoom that allows to render much faster except for the other is that differential screen drawing in 13h mode. I tried to do it once and it didn't work as intented. I came up with an A.asm assembly that does I_CopyLineDuke feature but instead of adding FPS, it dropped very slightly, unfortunately, must be done wrong.
Well some work is being done anyway.
Reply 3 of 8, by Darkcrafter07
MrFlibble wrote on 2025-06-22, 12:21:
I have tested it on a PCem's 386 - it works but really slow, Duke3D was made for 486 and the manuals say it btw, so it must be a really tedious task to make it work on a 386.
The approach published here actually still uses FPU but way less. I tested slopes on PCem's Cyrix 486DR2 (a faster 386 clone) and 486sx and according to "DNRATE" FPS indicator it worked almost as fast as on DX except for the awful image quality on slopes. I couldn't implement a proper horizontal interpolation so it's just where it is now.
I came up with some alternative purely integer math asm implementations of slope drawing routines. At this moment they look bad and work slower than my previous attempt, yet faster than the original FPU routines. Pretty interesting that they have an affine texture mapping routine there but I could never make it work as it crashes - might be that I made wrong declarations and pragmas in engine.c as they were never there and we can only guess how.
I have a feeling that we can speed up Duked3D on 486SX machines though, like calling those assembly wall drawing routines less often to decrease detailization or even drawing them in solid color replacing complex asm routines to simpler ones.
Reply 4 of 8, by Robbbert
Maybe you could fix that really annoying bug where if you chose weapon 1 (kick with boots), whenever you pick up ammo it auto-switches to that weapon instead, like it or not.
Reply 5 of 8, by leileilol
Darkcrafter07 wrote on 2025-06-22, 21:50:
The Build editor's 3d view runs significantly faster on slower 486s where Duke3D can't be played, so there's probably con overhead at play (probably a big part of ken's 'waste of time' wrt low detail mode)
long live PCem
Reply 6 of 8, by Darkcrafter07
leileilol wrote on 2025-06-23, 02:24:
That's some really interesting info I didn't know about. So I fed duke3d's game.c displayrooms and build's game.c drawscreen to AI and came up with the build version displayrooms for duke3d. In PCem on 486sx2-66 It doesn't have any extra bump in FPS compared to original but messed many things like sprites lighting, animation, logic and so on, maybe it's just AI.
I guess it's still better to perform less calls on asm routines to draw walls just like I did with nofpu on slopes but I need to find a way to interpolate that. Then we have to come up with a solution on how to implement Doom's fashion low end detail mode because Duke3D's simply renders screen in a small tile then stretches it up to the hires screen.
Reply 7 of 8, by Darkcrafter07
Duke07 update to v0.11:
- up to 768000 bytes MIDI playback.
- up to 10 custom 4-tile 256px width panoramic skies (defined
in DEFS.CON). Make sure for the names SKYCUSTOM1-SKYCUSTOM10
to stay the same. If you use a tile #3840, make sure you have
3 more tiles space left in your art file, e.g. #3841,3842,3843
must be free to fit remainig 3 parts of your sky.
All necessary example files included.
Reply 8 of 8, by Darkcrafter07
Duke07, v0.12 update:
- finally an "interpolated" way to do slopes with /nofpu flag.
Ken's unfinished "slopevlin2" approach now renamed to #0.
"slopevlin" duplicated and now is #2 approach, has its own
precision parameters, and most importantly, simulateneous pixel writes
to the sides, allowing to "interpolate" only those columns that were
requested in grouscan_nonfpu function in engine.c, frame parity removed
for a while but the file is still there if you will - engaltgs.c.
The a.asm changes:
; we now add this thing above
mov [ebp-1], al ; Pixel to the left - 1
;the original line below:
mov [ebp], al ; Center Pixel
; we now add this thing beneath
mov [ebp+1], al ; Pixel to the right + 1
you can iterate more to fill in the gaps
