First post, by noshutdown
former title is: whats the fastest 2d-only video card?
"2d-only video card" means cards without any 3d features, especially polygons or line drawing with 3d geometry transformation, and this excludes most matrox cards.
4mb ram is typically required, as 2mb would only allow up to 1024*768*16bpp and 800*600*24bpp, which seems too low.
here are some possible candidates:
s3 968(single cycle vram)
a potential best allrounder, vga and 8bpp svga performance is a bit below the top, but high resolution, truecolor, windows performance can be expected. supports up to 8mb vram, 250mhz ramdac and 1600*1200*24bpp mode!
s3 trio64v2(single cycle edo ram)
while fast, its datasheet indicates support for only up to 1024*768*16bpp and 800*600*24bpp even with 4mb of ram, which has no improvement over 2mb at all. and thats probably why few trio64v2 cards have ram slots for 4mb.
cirrus5480(sgram)
the previous 5446 is not stellar but quite decent, and the 5480 is 5446 updated with high clock sgram so expectations are high.
tseng et6100(mdram)
known to be fast, yet supported resolutions are subpar: only up to 1280*1024*16bpp and 1152*864*24bpp.
ati mach64gx(vram)
a bit too old compared to others but i believe its ati's last card using vram, the newer mach64ct/vt are low end models using edo ram and therefore not expected to be faster.
chips69030(integrated sdram)
this one is agp, and integrated sdram is expected to be faster.
the following cards are supposed to be less competitive as they used regular dram, but somewhat listed being the most advanced card without 3d features from the company:
alliance at24
alliance video cards were never very successful or popular, so expectations on it are low.
trident9685
trident was usually in the low end just like cirrus, but its 9440/9680/9685 got the job done decently, similar to the cirrus5446. 4mb cards exist.
ark2000
ark1000 was known to be fast, and the 2000 was still quite fast in dos tests, but quite rare and i doubt that 4mb cards ever existed.
avance logic 25128
very rare, little is known other than the name. although the low end alg2032 performed quite well for a 32bit card, i had a strange feeling that the gap between it and the high end 25128 would not be huge, just like alliance's at24 over 3210.
oak64107/64111
not that rare, but all cards i have seen were 2mb only, in contrast to 64107's datasheet claiming support for up to 8mb. limited test results were seen to be mediocre.
wd9710
quite rare and early, not expected to be very fast.
sis6215/6225
rare, little is known, not even supported ram size. few cards seen were 2mb, with the 6225 rumored to have some 3d features.
matrox atlas(vram)
a very old, high end, professional card with up to 240pins, dos performance is abysmal, even slower than fast isa cards, with windows performance unknown. anyway it was not remotely designed in the direction of consumer features.
