First post, by UCyborg
Currently, I use HP Laser Gaming Mouse with VoodooDNA. There were few other mice with the exact same design back then, but different brand. Well, HP had the same mouse called HP Omen X9000. Looking at the mice today, nothing alike exists. Do people vastly prefer horizontal alignment when it comes to those 2 buttons? I find it clunky.
The old one mostly still works, though right mouse button has a bit loose contact, have to hold at right spot a bit firmly for it to not release. Would be nice to be able to find a simple mouse like it.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1 of 5, by momaka
If the mouse was by HP, then chances are either Logitech or Mircosoft or some other big OEM (but really, I can only think of Logitech and MS as the only ones) are the manufacturers behind it and probably have similar models of their own.
I never got used to using side buttons. Two buttons and a wheel is all I need/like. However, I do dislike mice with horizontal side buttons quite a bit more than ones with vertical buttons. With vertical buttons, if the design is right, they just don't get in my way and I can still use the mouse normally (and usually ignore those buttons.) But with horizontal stuff, I keep mis-clicking them. Nothing like the badly-misplaced DPI buttons on some no-name "gamer" mice, though - those can be attrocious to use.
In regards to your right mouse button loosing contact...
Open the mouse and check it out. Does it use the regular rectangular buttons? If so, those are easy to replace... or even service! After a long life, you can open these and carefully wipe the contacts with 1000-grit sandpaper. Of course, only do that if that's even the problem. Sometimes the plastic on the top shell of the mouse can become worn/indented, preventing the mouse button from becoming fully pressed unless more pressure is put. For mice shell that use ABS plastic (vast majority of mice), this can be corrected by applying a few layers of PVC/ABS glue... or just glue a thin PVC or ABS sheet and sand it down.
FWIW, I'm still using my 2-button no-scrollwheel Logitech MS-34 ball mouse from 1999 as a daily driver. The left button has been opened a number of times now for cleaning (with 1000-grit sandpaper)... but it still works fine.
Reply 2 of 5, by UCyborg
The first one I had with this design was Icon7 Z500. I don't know which company actually thought it up. Something went wrong with it, but I no longer recall what.
Actually, this current HP one, the issue was much worse at some point in the past, but it seems it's just me adjusting over time. I'm incredibly clumsy, afraid to open it to not screw up anything further. So I'd rather leave it alone until the need is not pressing.
I'm one of those people who use arrow keys for movement in games rather than WSAD keys, my hand just doesn't work there properly. And having 2 extra actions on the mouse is incredibly handy. Vertical movement of my thumb comes naturally while horizontal, not so much, something about moving that joint.
Yours is holding up well it seems, over quarter of the century.
Reply 3 of 5, by robertmo3
you press one button with the tip of the thumb and the other one with the joint of the thumb - this also allows pressing both buttons at the same time - (not possible with your vertical)
very few mouse have those buttons comfortable. i found good mice for that is razor deathadder and steelseries rival 300 (but razor has hard to press scroll so we are left with steelseries which allows modifying sroll press force by opening button and bending plate)
Reply 4 of 5, by UCyborg
IDK, I just don't find it natural. My brain computes / maps vertical thumb up / down movement to the action I want faster than considering gymnastic with joint. Backwards / forwards in web browser / Explorer is always exclusive and in games, I have them for reload and melee, which usually can't be performed at the same time, so inability to press them simultaneously never bothered me. Guess I'm sticking to the old one 'till it falls apart.
Reply 5 of 5, by UCyborg
I haven't been looking for new mouse since, but the issue with old one's right button somehow solved itself. The computer's PSU was replaced couple of months ago and most probably the mouse was also unplugged and plugged back.
I did encounter another problem with USB recently that the phone wouldn't charge or would do extremely slow, where disconnecting and connecting cable again helped. I have the other end of the cable plugged into computer all the time.
