First post, by mitradis
As everyone knows, the NVIDIA has stopped supporting 32-bit PhysX. I didn't quite understand the essence of the matter. But I immediately had a lot of thoughts about how this could possibly be resolved.
-Is it possible that in the future there will be some kind of wrapper (not dg, third party, is it even possible?) for support?
-Since the 64-bit version continues to be supported, is it possible to convert the API?
-(most likely not) but is it possible to convert something using the dgVoodoo to transform the commands into a working API version?
-possibly other completely crazy and idiotic ideas =))
I would like to hear an answer from a professional, an author dgVoodoo Dege.
Reply 1 of 9, by DarcTangent
Nvidia should do this in the driver. If they do not, it would be nice if someone could make a wrapper. Right now I use an older secondary card on a x4 lane that is separate from the primary GPU.
Cheers!
Reply 3 of 9, by myne
The 4000s still support it, yes?
99% likely if you go through the driver infs you'll:
Figure out which one controls physx.
Then spot the difference in paths the installer takes.
Then mod it successfully.
I built:
Reply 4 of 9, by Trashbytes
Its not a driver issue, its a direct hardware one, nVidia is totally to blame here and I'm not even sure why they decided to remove 32bit Physx but I see it ever being fixed till nVidia does it or someone out there decides to sit down and write a wrapper to convert every single 32bit Physx call into the 64bit API . I really don't see nVidia even bothering with it, they want devs to move to 64bit Physx functions and honestly us consumers are just an after thought to nVidia now, they have their AI money and don't need us, I fully expect nVidia to move out of the GPU market in the next 5-10 years.
Its task I wouldn't wish upon anyone, itll be a huge task and honestly its far easier to just throw a 1660 or 1060 in the PC to handle the 32bit Physx, you don't need anything powerful or expensive for that task, even a dirt cheap 750ti could handle it.
Never forget nVidia does this bullshit all the time, they did it with DLSS and other features locking them behind hardware or manufactured hardware limitations.
Reply 5 of 9, by Squall Leonhart
myne wrote on 2025-06-25, 05:56:
The 4000s still support it, yes? […]
🤣, no.
The 32bit Cuda dll has no supporting code to communicate with the blackwell kernel.
Trashbytes wrote on 2025-06-25, 06:25:
Incorrect.
The NVCC in the cuda toolkit has not been updated to generate blackwell assembly in the 32 bit emitter, so the cuda dlls supplied with the driver only supports blackwell on the 64bit variant, leaving Lovelace as the final cuda capable chip for the 32bit runtime.
https://forums.developer.nvidia.com/t/whats-t … ications/323106
Reply 6 of 9, by Trashbytes
Squall Leonhart wrote on 2025-07-28, 17:38:
lol, no. […]
🤣, no.
Incorrect.
So typical Novideo behaviour.
Still a hardware issue a nvidia specific one only affecting thier hardware caused by their own greed.
Reply 8 of 9, by DosFreak
The last commit was on April 2025.
We already have a thread for this and I don't know what you'd post here when the op was asking dege specifically.
This thread is out of scope for dgvoodoo which is likely why he hasn't responded to this thread created on 6/2025 which predates Nvidia adding support 32bit physx support on 12/2025 for some games but likely also for more than they list:
Re: NVIDIA's 32-Bit PhysX Waves Goodbye with GeForce RTX 50 Series Ending 32-Bit CUDA Software Support
https://old.reddit.com/r/nvidia/comments/1pe3 … _32bit/ns9f8ic/
Make your games work offline
Reply 9 of 9, by Dege
Btw, is this issue still prevalent and important to handle?
How many games are out there that use 32 bit PhysX 2.x through the GPU?
As far as I know, not so many and NV even released fixes for the most important/popular ones.
