First post, by crustyman9000
When I assembled the board + cpu and applied power, the new PSU showed a brief moment of fan movement but then stopped. I checked to see if the connections were good, and they were (front panel, 20pin out etc). I suspected some kind of short or maybe the cpu cart wasn't slotted in correctly (the mb lacks the slot 1 retention bracket). Strangely enough I was able to make the system post a few times after reseating the cpu multiple times and fiddling with its position in the slot. I would never get it to post if it was fully slotted in though and most of the time it would just PSU fan spin then nothing.
I swapped out the new PSU with an older (ATX psu but not in form factor) psu. It posts reliably now with zero issue. Why is this happening? I heard from somewhere that some modern ATX PSUs aren't compatible with older boards like this because of difference in ATX standard implementation over the years. Is there is a hack for correcting this? I don't have my voltmeter with me atm but I'll try to take some readings later on. It seems that 20pin pinouts are identical between the two PSUs with only -5v missing on the new one (there might of been one additional wire missing on new PSU, ill check when i get home).
The new PSU is a EVGA 500 W1
