First post, by EvilTurkeySlices
Hello, I have a 486 machine that I am trying to get an IDE CD working on. The sound card I installed has IDE, so I figured I'd use that. Unfortunately, I have been unable to get it working so far after a few hours of troubleshooting. I have tried several cables, several drives, and I have tried editing the Autoexec and config.sys many times. I have gotten it to where the driver ties to load, but finds no drives at all.
This is the card if it helps:
https://theretroweb.com/expansioncards/s/beha … -tech-btc-1853l
And here are the autoexec and config.sys:
The attachment GuT8XvqWgAAPvJr.jpg is no longer available
The attachment GuT8XwNWwAAS_4d.jpg is no longer available
Here's the computer and the messages at startup
The attachment GuT8XvrWkAAz7Vw.jpg is no longer available
The attachment GuT8XvnWIAAbLgQ.jpg is no longer available
Reply 1 of 9, by weedeewee
from the trw photo it seems like the ide controller works on irq 12 or 15, yet your config sys refers the vide-cdd.sys to look at irq 11.
I think that should be the first thing to correct.
Do not ask Why !
Reply 2 of 9, by EvilTurkeySlices
weedeewee wrote on 2025-06-25, 20:44:
I changed it to look at 12(what it’s jumpered at) but that didn’t seem to help. I also changed the i:b to an i:a to see if that didn’t anything. Nothing changed.
Reply 3 of 9, by Grzyb
It seems that flashing the ROM may help - Can't use IDE port on BTC 1857i card
But note that was about an ES1869 card, while yours is based on ES1868.
Decide for yourself if you want to take the risk...
Nie rzucim ziemi, skąd nasz root!
Reply 4 of 9, by DivByZero
EvilTurkeySlices wrote on 2025-06-25, 20:59:
The letter after the "i:" is actually a hex number. a = 10, b = 11. You want to use "i:c", which will select IRQ12, what your card is jumpered for. That should get it working.
Reply 5 of 9, by DaveDDS
Does the mainboard itself have a spare IDE?
When add-in cards have the same peripherals as the mainboard, I always think about possible conflicts.
If the mainboard has an available one, I'd remove the sound card and see if I can get the drive working
directly connected to the mainboard (and your BIOS might be able to report seeing it) - even if you ultimately
want to put it on the other interface, this would at least tell you if other things are configured right..
I assume you've already checked that the drive is jumpered correctly - drives could have been left jumpered
either way - when placed alone on a secondary IDC channel, they were usually jumpered as drive 1. When
daisy changed with the main IDE hard drive they were usually jumpered as drive 2.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 6 of 9, by EvilTurkeySlices
DivByZero wrote on 2025-06-25, 23:49:
I’ll have to try that, that might be it. I’m sure it would have been easy if the manual actually told me that(which it didn’t)
Reply 7 of 9, by EvilTurkeySlices
DaveDDS wrote on 2025-06-26, 00:51:
Does the mainboard itself have a spare IDE? […]
No onboard IO, so I have multi IO card. It only has one IDE channel, and I’m not sure it supports atapi devices.
Reply 8 of 9, by darry
If there is a PS/2 mouse connected (or maybe even PS/2 mouse support active without an actual physical mouse connected), using IRQ12 for whatever else may be problematic.
Reply 9 of 9, by myne
EvilTurkeySlices wrote on 2025-06-26, 01:36:
Try jumpering it for irq15 then
I built:
