First post, by yabobay
I assume some of the details asked for in the guidelines aren't relevant since i'm using DOSBox, but my DOSBox version is 0.74-3, i haven't changed any of the default settings except for setting machine=svga_et4000, which was required to install display drivers.
I've tried mounting it at d, e, D, E, D:, and E:, this happens every time.
The attachment dosbox_000.png is no longer available
The attachment krnl386_003.png is no longer available
Reply 1 of 4, by leileilol
It's likely not seeing the disc's label (THEROCK), so you could try mounting the iso on linux instead and use the mount command on that with -label THEROCK
long live PCem
Debian's fucked
Reply 2 of 4, by jmarsh
ISO files support volume labels, if the ISO image is correct it should just work. I'm wondering if there's separate win3.1 / win95 builds and the win3.1 version is just broken because it was never tested properly - wouldn't be the first time.
Reply 3 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Information on MobyGames suggests it might be a PC/Mac hybrid disc. You will need an SVN build of DOSBox if a DIR in the subdirectories shows some filenames listed twice, indicating the presence of Mac resource fork data.
Reply 4 of 4, by yabobay
leileilol wrote on 2025-06-27, 16:48:
That worked! Kind of upsetting that it doesn't just work when mounting the image. I don't understand why, since if i run mount after mounting the image normally it does say the label, so that shouldn't be a problem?
