First post, by schlang
Hello, my Windows 98 SE is making a weird pause during startup. Before it loads the GUI it just sits there doing nothing, the HDD is not reading anything.
It's always the same on every start, always the same duration. Any way I can find out what's causing this? Is it the Ethernet card? I have dark memories from 25 years ago...
Thank you
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 1 of 7, by jakethompson1
DHCP but no cable connected added a delay; I thought that got fixed between original and SE
Reply 2 of 7, by Repo Man11
It most likely is the network connection that is causing this. Since I don't use a network with my Win98 machines, I either don't install a card, or I disable the on board network port. I just saw this on Reddit, I've never tried it, but it cured the problem for this person.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 3 of 7, by schlang
Thank you I disabled DHCP and assigned the IP manually, I feel the startup is faster however there is still 10 seconds where nothing is happening before the GUI is loading
Reply 4 of 7, by pete8475
schlang wrote on 2025-07-05, 23:18:
That always happens to me with 98SE, ME fixes that issue but some don't like that OS for other reasons.
aka pete4237.5
Reply 5 of 7, by schlang
I checked with boot log analyzer and I waste 6 seconds on this:
I7yL7LlEwtyb.png?o=1
InitDone = TSRQuery (Time Estimated)
Reply 6 of 7, by schlang
pete8475 wrote on 2025-07-05, 23:25:
The static IP improves startup from 30 seconds init time for the NIC to 9 seconds init time
Reply 7 of 7, by pete8475
schlang wrote on 2025-07-06, 12:43:
Yep.
aka pete4237.5
