First post, by UCyborg
Something unusual I've been noticing for a while, but only now brought up since I only fire up Flash Player occasionally. I'm not sure if it's Windows or drivers, but I'm noticing things animating in Flash are a bit choppy under Windows 10 while they're still fine on Windows Vista. Not sure about 7, haven't booted that OS in a long while.
This with latest official international version of Flash Player 32.0.0.465 that was discontinued (needs patching out the time bomb) and the newer version (currently at 34.0.0.330) being maintained for Chinese, easily obtainable at https://github.com/TCOTC/CleanFlash_Installer.
Running it in a browser is a bit worse than standalone player, but it's also noticeable in standalone player.
I like Crush the Castle 2 for comparisons, on every level, camera goes from the crash site to player's catapult, the jerkiness of camera movement is painfully obvious.
For the above web site to work properly with Pale Moon (one of the last good web browsers with Flash support), you need this filter in uBlock Origin to block Ruffle (poor Flash emulator):
||unpkg.com/@ruffle-rs/*$script
And the following user style (userContent.css, Stylem...) to fix the size of the game container:
@-moz-document url-prefix("https://www.y8.com/games/") {
.item-direct-container {
height: calc((100vw - 345px) * 5/8) !important;
What's funny, both standalone versions seem to use D3D11 according to MSI Afterburner, so I guess the idea of wrapping old D3D to new one is out.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 2 of 2, by UCyborg
I'm familiar with Basilisk, used it for couple of years. Though when I figured I can use PassIFox instead of KeeFox and that there's a config option to turn on NPAPI plugin indicator in Pale Moon, I switched to Pale Moon. Also don't need another extension to undo changes that come with Australis interface.
It was said on another forum that Flash got slower with newer versions and started requiring SSE2 instructions at some point.
Oh, that CSS above for y8.com is not correct, cuts off some portions, I figured this user script works better, DuckDuckGo says padding-bottom property can be used for proper scaling if aspect-ratio is not supported.
// ==UserScript==
// @name Y8 aspect ratio fix
// @namespace https://github.com/UCyborg
// @version 1.0
// @author UCyborg
// @match https://www.y8.com/games/*
// @grant none
// ==/UserScript==
'use strict';
setTimeout(() => {
var el = document.getElementById('item-direct-container');
if (el) {
el.style = 'position: absolute;';
el.parentElement.style = 'padding-bottom: 70%;';
}, 250);
That site's scripting also apparently relies on deprecated window.event, has to be either specifically enabled in about:config (dom.window.event.enabled) or use the suggested filter in this thread on Pale Moon forum.
