First post, by simonh27
I am a complete novice with a soldering etc but I recently puchased a defective Diamond Monster 3D
Initially the memory was not detect and that turned out to be loose pins on the TMU so now it looks like everything is detected but when entering 3DFX mode I only get a black screen (tried with a passthrough and directly to the card)
Running mojo it all seems to be detected as should
Below is the log, anyone have any idea what the issue could be?
Thanks
sst1Init Routines: InitCode $Revision: 5 $sst1InitMapBoard(): BoardsInSystem = 1sst1InitMapBoard(): vAddr:0x10400000 pAddr:0xf6000008 Dev:0xe Board:0sst1InitRegisters(): Setting TREX-to-FBI FIFO THRESHOLD to 0x8...sst1InitRegisters(): Setting PRELIM FT-CLK delay to 0x8...sst1InitDacDetect(): Entered...sst1InitDacDetectICS(): Entered...dacWr(0x7,0xb)dacRd(0x5,0x79)dacRd(0x5,0x2e)dacWr(0x7,0x1)dacRd(0x5,0x55)dacRd(0x5,0x49)dacWr(0x7,0x7)dacRd(0x5,0x71)dacRd(0x5,0x29)sst1InitDacDetectICS(): Exiting...sst1InitRegisters(): Storing TREX0INIT0=0x5441sst1InitRegisters(): Storing TREX0INIT1=0xf420sst1InitRegisters(): Storing TREX1INIT0=0x5441sst1InitRegisters(): Storing TREX1INIT1=0xf420sst1InitRegisters(): Storing TREX2INIT0=0x5441sst1InitRegisters(): Storing TREX2INIT1=0xf420sst1InitSetGrxClk(): Entered...dacWr(0x7,0xe)dacRd(0x5,0x0)dacWr(0x4,0xa)dacWr(0x5,0x7b)dacWr(0x5,0x6c)dacWr(0x4,0xe)dacWr(0x5,0x0)sst1InitRegisters(): Setting up FAST DRAM Configurationsst1DeviceInfo: Board ID: Obsidian GEsst1DeviceInfo: FbiConfig:0x2, TmuConfig:0x11sst1DeviceInfo: FBI Revision:2, TMU Revison:1, Num TMUs:1sst1DeviceInfo: FBI Memory:2, TMU[0] Memory:2sst1DeviceInfo: Dac Type: ICS ICS5342sst1DeviceInfo: SliDetect:0sst1InitRegisters(): LFB Writes go through memory FIFO...sst1InitRegisters(): TEXTURE Writes go through memory FIFO...sst1InitRegisters(): exiting with status 1...sst1InitShutdown(): Shutting down SST-1 #0...sst1InitSetGrxClk(): Entered...dacWr(0x7,0xe)dacRd(0x5,0x0)dacWr(0x4,0xa)dacWr(0x5,0x41)dacWr(0x5,0x62)dacWr(0x4,0xe)dacWr(0x5,0x0)sst1InitShutdown(): Returning with status 1...
