First post, by Stovebolt_66
I've looked over this and other sites but trying to figure this out on my own isn't getting me anywhere.
I have a Desktop PC I use all the time, running Windows 10 PRO, 64-bit, 8 GB of Ram., connected to high-speed internet via ethernet cable to a router. My old computer (the first one I bought in 1999) is a Compaq Presario desktop 5304, running Win98se with 188 M of Ram (maxed out).
Is it possible to connect my old PC to my new one so I can transfer files between them? I do not want to connect the old Win98 to the internet, just my new (main computer).
I've read a lot of stuff online about how this works but it's a bit over my head. Is this is an impossible idea due to the computers' age and OS differences, no problem, I'll just know not to keep chasing it.
Thanks in advance for any advice/help.
P.S. Most of what I can do with files and stuff comes from modding various racing sims.
Reply 1 of 15, by Archer57
If you just want to transfer files and do not need SMB to work, aka being able to use "network drive" etc, you can simply use FTP and then it's super easy to setup. You can use something like filezilla for a server and whatever client works on 98 (total commander?).
To avoid connecting to the internet when plugged into the router - configure network settings manually (IP/netmask) and do not set default gateway.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 15, by Stovebolt_66
Thanks. I forgot to add that the older PC has a Belkin PCI card, the old dial up modem has long since been removed.
Reply 3 of 15, by DaveDDS
Stovebolt_66 wrote on 2025-07-09, 16:17:
You can FTP over any internet connection... not just a dial-up.
Couple other things worth mentioning:
The older system probably supports an older/insecure version of SMB. I've not done this in W10, but at least W7 could
be configured to support older SMB versions (which are disabled by default).
If you really want to block the older machine from the internet, you can probably do so in your router, allowing it
to connect to other things on the local network, but not the internet gateway.
I move files over the network between DOS and Win7/Win10 all the time. This also works well in
W98 and requires DosBox on the Win64 end... If this might be of interest, I can post details.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 4 of 15, by Stovebolt_66
If you don't mind I would be interested, I already have DosBox and DosBoxstaging on the new machine, I use them to run some of the early DOS based racing sims.
Reply 5 of 15, by Stovebolt_66
I'll add that I don't necessarily have to block the internet from the old PC, it's just that I'm leery of trying to connect it with Win98. In trying to educate myself and reading thru this forum and others, I gather there are lots of folks still accessing the net with Win98 no problem, but they are much more computer savvy than I am and I think some are using some sort of home-built browser, which is again way, way over my head. The old PC sat in my closet for years; I kept it even after I upgraded to newer PCs with newer OS. It's a really good machine and I really like W98se. I'm not working full time anymore and decided to fire the old one back up, it was like seeing a long-lost friend when the home screen came up.
Reply 6 of 15, by chinny22
Dial up modem would be useless for what your trying to do so that is fine.
Double checking the Belkin card is a standard network card and not wireless?
Simplest option would be connect both computers to your router via ethernet cables.
Then as Archer57 said use a ftp program to transfer the files as this doesn't care what versions of windows you are using.
Technically the Win98 PC would have internet but it will be safe behind the router firewall and for the few hours of gaming would pose almost no risk.
(this is similar to my setup and never had an issue)
Windows networking uses SMB as DaveDDS mentions. This can be made to work but takes alot more effort. Personally I prefer this as I find it more convenient with over 10 machines.
but ftp not only gives you faster transfer speed but alot less initial setup required
Reply 7 of 15, by Archer57
chinny22 wrote on 2025-07-10, 05:48:
My issue with that is - it requires enabling a bunch of insecure legacy stuff on modern system to work. It is not the end of the world, but a disadvantage to consider. Especially if modern system is a laptop and may get connected to public wifi or something at some point.
It is possible to build a linux NAS which would run 2 different instances of samba on different interfaces sharing the same storage, one configured to be compatible with old stuff, another - with new stuff. I've been meaning to do that for a while, even did software configuration required, but... i am lazy and i just transfer stuff using thumb drives. The biggest thing that is stopping me from doing this is having to add extra switch and cables to each old system - that'll add significantly to already quite bad rat's nest of cables...
There is also something special about having truly offline system this days, with no network connected at all...
Reply 8 of 15, by kotel
DaveDDS wrote on 2025-07-09, 18:33:
W10 support SMBv1, you need to enable it in control panel>programs and functions>turn windows features on or off>SMB 1.0/CIFS file sharing service.
But in my opinion, I had so much issues trying to get my SMBv1 share from server 2k3 r2 working on w10 that I just gave up on it. IIRC XP will work with the more secure SMBv2 shares used on server 2012 r2.
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
Reply 9 of 15, by DaveDDS
Stovebolt_66 wrote on 2025-07-09, 19:18:
I have a thread about it, see: DDLINK: Easily move files between/To/From DOS systems
Be aware that it doesn't provide "shares", it is literally a file transfer
program. It's really nice in DOS because unlike FTP you don't need a TCP
"stack" or any other networking protocol support installed.
All you need is a DOS "packet driver" for you network card (these are
readily available for many NICs).
And since it uses a proprietary network protocol that is not-routable, it is
very secure against the "outside world".
DDLINK can also transfers files over PARALLEL (pretty much only DOS<>DOS
and SERIAL (also works with DosBox).
It is a 16-bit DOS program, it will run under 32-bit windows but not 64-bit
so you have to use DosBox. Under Win32 you can use something like SWSVPKT
to provide a packet driver - you'll need a network enabled DosBox (and
something like WINPCAP to enable DosBox virtual NE2000 NIC) om Win64.
Reply 10 of 15, by Stovebolt_66
Thanks everybody! I'll try out some of this and see where it goes. I feel kind of dumb, a jump drive to transfer files never occurred to me, I'm so old fashioned and behind the times I was trying to avoid burning cd's to that. I still would rather have the two connected, and learning how all this stuff works is really interesting and I'm enjoying that part of it. You folks are great!
Reply 11 of 15, by chinny22
Stovebolt_66 wrote on 2025-07-10, 12:38:
Don't feel dumb. USB was still in early days during Win98 so is slow and can be a challenge to find a drive that likes Win98.
Network on the other hand was already well established so still more reliable in the long run
Reply 12 of 15, by DaveDDS
... I move files over the network between DOS and Win7/Win10 all the time. This also works well in
I probably should have also mentioned that if you have any trouble getting a network "packet"
interface to work in Winblows98 - you can always boot it to DOS, load a standard DOS packet
driver and still do transfers.
Reply 13 of 15, by Stovebolt_66
Thought I would give an update: First of all, thank you all again for all the help, I really appreciate it. The old Compaq win98se PC was doing great, I got it connected to my router, even got online with the K-Meleon browser, but it was not very good. I was using jump drives to transfer files and was able to run some of the old converters for track conversions for older racing sims, I enjoyed that. I was in the process of setting up a network through the router when the old girl up and croaked on me, the hard drive screeched like a barn owl and that was all she wrote. It wouldn't even start up off the boot floppy or run the total restore disk. I have no complaints, I bought it at Best Buy in Charlotte, NC in the fall of 1999, it served me well off and on for 26 years. The good thing that came out of all this is that I learned a lot and continue to learn. I took the monitor and connected it so I now have dual monitors on this PC, and I'm about to add an external hard drive for more space. I'm also looking at using Virtual Box or one of the other programs so I can still run some of those older win95/98 based games. I already use DosBox and DosBox staging for Dos based games so I think I'll figure that out. I parted out the old Compaq and saved the CD-ROM drive, floppy drive, and power block as they still work, plus the keyboard too. May need it one day, never say never. Thank you all again for helping me not be so computer ignorant.
Reply 14 of 15, by RetroPCCupboard
I haven't got to the stage of networking my retro PCs yet but I am weary of putting them on the same network as my modern PCs. I was planning to put two network cards in my Linux-based NAS. One network card for retro network, and one for modern network. The NAS at least has the advantage of having an abundance of space and is fault tolerant to disk failures. The NAS already has a library of hundreds of games (mostly feom GOG) and many ISO CD/DVD images.
Reply 15 of 15, by RetroPCCupboard
Stovebolt_66 wrote on 2025-07-31, 00:29:
I am sorry for your loss. If it was just the HDD that failed, then I would think the the PC should be fine if you put in new HDD? Same thing happened to my Pentium 233Mhz machine.
Virtualbox/vmware arent that great for gaming. I think x86box or PCEm would be better, though you need a fast PC if you want to play more demanding games.
