First post, by Bs0Dd
- Newbie
I recently received a working Halikan LA3540 laptop.
There is almost no information about it on the Internet, so I had to figure it out myself.
Main characteristics:
- Harris CS80C286-20 processor (and a place for the 80287)
- C&T 82C2xx chipset (NEAT CS8221)
- 1MB RAM (2 banks with 4x 256k chips - MB81C4256-80PSZ)
- Stingray Rev 4+ VGA card (CL-GD610/620 chips with BT471KPJ50 RAMDAC and 256k VRAM - 8x D41464L-80 chips)
- Epson SMD-300 FDD (1.44MB 3.5")
- Conner CP3000 HDD (41MB IDE, Type 42)
- 2x COM (DB9 and proprietary), 1x LPT, Keyboard connector (PS/2?), VGA out
- ISA16 and ISA8 slots (the NE1000 network card is very useful here!)
- Grayscale VGA LCD
Here AMI BIOS with XCMOS is used, but in ROM there is only the main CMOS setup and the DIAGS utility.
So for XCMOS setup (and to fix the "XCMOS checksum failure" error) you can use NEAT QUICKSET or SETNEAT: https://www.dosdays.co.uk/topics/neat_chipset.php
For the Stingray VGA (mine has BIOS v3.02) card there are CLUtils: https://www.dosdays.co.uk/topics/Manufacturer … gic/clgd610.php
But there is a problem with this VGA card when using external monitor via VGA out.
Some colors seems to be shown incorrectly.
There are correct colors (XT 5160 with Oak OTIVGA 067):
And the same tests with Stingray and grayscale LCD:
But when I using "external display mode", there are problems with some light colors:
You may notice that, for example, the light gray color (in the cga palette) is somehow indistinguishable from white (which already creates problems).
Some bright shades look the same or are completely white.
What could be the reason? RAMDAC?
I also noticed that there is a set of jumpers near RAMDAC, but their purpose is unknown to me and I am not sure if this is related to the video.
