First post, by Beatoven
Hi all,
Apologies in advance if this has already been covered somewhere (I did search first, I promise!), but does anyone know the jumper settings to make a Cyrix 5x86-120 CPU work properly on a PC Chips M915i? I have V1.3 of this board, which lacks onboard IDE controllers, if it makes any difference.
Settings for just about every CPU except this one are screen printed on the board, and I can get it to post using the Cyrix DX or SX configurations. However, the system hangs and the BIOS displays incorrect info, such as the wrong speed and calling it a "487". The board works fine with other CPUs so I'm almost certain the cause is an incorrect setting somewhere.
Thanks for your help!
Tim
