First post, by bodella
Hey everyone,
I literally feel like im about to have a mental breakdown from going round and round in circles trying to get something to work. I have a compaq portable 486c computer that turns on but nothing else after the disk check.
I’m currently trying to recreate the original 4 setup/diagnostic disks for the Compaq Portable 486c, which are delivered through a SoftPaq file: SP1971.EXE. (I think, if anyone knows the right softpaq please let me know)
What I'm Trying to Do:
I want to run SP1971.EXE and extract its contents to create 4 bootable floppy disk images (1.44MB each), just like the originals Compaq provided.
Once I have those .img files, I plan to write them to real floppy disks using my USB floppy drive and use them with my actual hardware.
What I’ve Tried So Far:
I’ve run FreeDOS inside QEMU and VirtualBox.
I mounted SP1971.EXE from an ISO and tried running it inside the VM.
I also created blank .img floppy files and attempted to write to them from within FreeDOS.
I formatted those images using format a: and verified they work.
But every time I run the SoftPaq, I get a "Disk failure" or "Drive not ready" error when it tries to write to A:.
My Current Thinking:
I suspect the problem is:
Either the SoftPaq doesn’t like virtual floppy drives in QEMU/VirtualBox
Or there’s something FreeDOS is missing that MS-DOS or a real DOS machine would handle properly
What I Need:
Would anyone here be willing to:
Run SP1971.EXE on a real DOS machine or reliable MS-DOS VM
Let it create the 4 floppy disks
Then dump them to .img files (e.g. using WinImage or dd)
And share those 4 disk images?
Once I have those .img files, I can write them to real floppies on my end and archive them for the community.
Thanks in advance — I’d really appreciate any help. If you’ve successfully created these disks before, even just advice would be welcome! Becqause im just stuck and confused at this point.
