First post, by The Fritz
Hi everyone,
I own an original ASUS 486/25 motherboard (as listed here: https://theretroweb.com/motherboards/s/asus-486-25) in excellent condition.
Unfortunately, I’m missing the external memory card required for RAM expansion.
The board powers up and POSTs up to the RAM check using a POST analyzer, but obviously can’t continue without memory.
I’m looking for:
Technical data, photos, or measurements of the original memory card
Pinout information for the memory card connector
Any experience or documentation about building a replacement card or reproduction project
If anyone has an original card, I'd also be interested in photos or detailed scans.
Thank you very much in advance!
Reply 1 of 1, by vetz
It could well be that the memory expansion board is compatible with other early ASUS 486 boards. The connector looks to be the same.
Check out ASUS ISA-486C. There are pictures of the memory card on TRW.
There's a card for sale on Ebay right now. https://www.ebay.com/itm/357028305138
Also vogons user Amigaz appear to own such a card: isa 386c cache apparently not working [now fixed]
PS. You should take pictures and dump the BIOS for your board and upload to TheRetroWeb as its missing for your board. I've also never heard about the 486/25 so it must be rare.
