First post, by ferrari2k
Hi, I am new here and just got my hands on an old Schneider PC1512 that has a harddisk included which still runs and has quite the software collection on it.
Before I try anything with that I would love to image that.
Normally with modern hardware you throw the harddisk in question into a USB enclosure, plug it into Linux and run dd. But with that old system? No Linux, just DOS, no connection to nothing... I would even use the 360k floppy if I must but... is there a backup software that does this?
I am currently trying to connect my Iomega ZIP drive via the parallel port but that is like just the destination bit. I still need something like dd which can image the harddisk.
Can anyone help me out with that? 😀
Reply 1 of 16, by Harry Potter
Do you need an absolute image of the drive? Or do you just need the information? If the latter, you can Google PKZip or DOSRAR, and they can compress the contents of the hard drive. I think DOSRAR requires a 386 or better, while PKZip should work on an 8086. I can also recommend some alternate DOS drives that are more efficient than the original and ways to better your system's memory configuration. Want them?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 2 of 16, by ferrari2k
I'd like both to be honest.
The drive is copying the data at the moment via Norton Commander to the Zip drive, I got that working with this driver, no problem: https://dosreloaded.de/forum/thread/8430-zip- … 5150-und-neuer/
I found a version of Norton Backup and will try that for imaging when the copying is done.
I'd like to image the drive because I'm certain I will have problems restoring the drive to the current configuration should I ever want to return to it.
Reply 3 of 16, by Harry Potter
Okay. I believe I can help you optimize your system's performance. Do you want it?
Reply 4 of 16, by maxtherabbit
Ok I'm imagining it
Reply 6 of 16, by ferrari2k
Harry Potter wrote on 2025-07-19, 23:53:
Not at the moment, thanks, I'm still in the process of learning 😀
Reply 7 of 16, by ferrari2k
OK so, the copying ran through the night and was mostly successful, I even got a bootable floppy disk out of the existing system so I feel pretty confident I would be able to restore anything on there.
Problem is, there are a lot of reading errors (as to be expected) so I would need something like ddrescue...
I also have some 486 machines, is it possible to insert a MFM controller to access the harddisk there? Would make things a lot easier.
Reply 8 of 16, by Errius
Yes, that's what I did in a similar situation many years ago. I just put the drive and the controller into a Windows 98 machine (configuring it as drive D: via jumpers) and then imaged it using WinImage.
ETA: This will not work if the drive has physical damage though. (Read errors). WinImage cannot handle that.
I had another drive (IDE) with this problem and used ROBOCOPY with /MIR /R:0 /W:0 options (run multiple times over several days, with the drive kept in freezer overnight) to recover about 95% of the files. ROBOCOPY is not available in Windows 98 though.
Is this too much voodoo?
Reply 9 of 16, by Grzyb
I did HDD imaging on XT-class machines.
Example solution:
- insert a NIC, popular 3C509B should work in 8-bit slot if configured for IRQ<=7, there are also LPT NICs
- set up mTCP NetDrive, or any other network-attached storage
- use DISKEDIT from Norton Utilities - https://forum.vcfed.org/index.php?threads/dum … 99/#post-741177
Nie rzucim ziemi, skąd nasz root!
Reply 10 of 16, by mbbrutman
I've also done this over the network, but using a small program that just reads every sector using BIOS calls. The end result is a full image of the hard drive. With a little more work the DOS partitions can be extracted and loopback mounted under Linux, or even used with mTCP NetDrive as a remote hard drive.
If you have done your imaging already then you are set. If you need help then send me an email.
Reply 11 of 16, by ferrari2k
Hi, thanks for all your help, I ran Norton Backup and it went successfully but there were some read errors but in stuff I wasn't really interested in so I thought, hey, let's test that low-level format with debug, never done that before 😀
Did that, worked fine, started fdisk and... error. So for me basically that harddrive is dead and I think I would be better off with an emulator or such.
Reply 12 of 16, by ferrari2k
But what I am planning to do is to backup the ROMs from that PC (I just found english PC1512 ROMs, no german ones) and from the WD RLL controller card.
Reply 13 of 16, by Jo22
Hint: PCem/86Box support emulation of PC1512/PC1640.
So if you have the ROM sets, these PCs can be emulated. In various languages. Probably.
Reply 14 of 16, by JohnElliott
ferrari2k wrote on 2025-07-23, 20:40:
The BIOS ROM contains multiple languages - they're selected with option links on the motherboard.
Reply 15 of 16, by ferrari2k
JohnElliott wrote on 2025-07-25, 14:22:
That's nice to know, I haven't gotten the time to look into that just yet. 😀
Reply 16 of 16, by ferrari2k
So I am quite proud of myself, just managed to get a ROM dump of the german PC1512. Is there any place where I would upload that or do I just put it here in some post?
