First post, by Guest
hey everyone
im new to this. i have just gotten a copy of glidos to play my origional tombraider game and have followed all the instructions although i found it didnt tell me how i should go about installing the unfinnished business cd.
any help would be great.
thanx
Reply 1 of 2, by Glidos
Just install it as you would if without Glidos (maybe leaving the sound card setup as "No Sound"). One of the things installed by that will be a setup program, "setupub.exe" maybe. Right-click on that and select "Run with VDMS" (i.e., run it under VDMSound). That will let you autodetect the sound card settings. Then copy the voodoo version of Tombub.exe from the cd into c:\TOMBRAID
Reply 2 of 2, by Guest
The latest Tomb Raider Installer allows you to install the unfinished business.
