TOCA 2 not running anymore on W98 PC
First post, by Nicolas 2000
W98 sp2
Gigabyte Via Pro133 motherboard with correct chipset drivers.
P3 1000
512mb ram
2x voodoo2 12mb sli
Geforce 4 ti4200
Sb audigy2
Dx7/dx9 (I've tried both)
I used to run TOCA 2 just fine on this PC using the Voodoo's. Since a hardware change (256mb ram to 512 and Rage to geforce 4 Ti4200) with full pc reinstall, it still installs fine, but won't run launcher.exe. The screen goes black for a second (switching to voodoos) And then returns to desktop with an error. The error I get is:
Launcher caused an invalid page fault in module launcher.exe at 0167:004153fb. Registers: etc. (I'll post the rest if required)
I have to press "ok" 8 times before it disappears.
If I disable the voodoos in device manager, I get a few seconds of hourglass and then nothing, no errors but also no setup program.
I've tried it under dx9. Eradicated dx9 and installed dx7. Set desktop to 800x600x16. Tried full Toca2 install and minimal. With and without the Toca2 V4.1 patch from the CD.
All my other games (voodoo and geforce) and 3dmark99 work perfectly, both voodoo and geforce.
Any idea what I can try?
Reply 1 of 26, by akula65
Looking at the Requirements and Patch sections on the old Codemasters page, the game was written for DirectX 6. The Patch page indicates that DirectPlay Version 6.1a is included with the official Version 4.1 patch. When you install the game, do you completely bypass DirectX 6 installation, or do you let it run and install any needed components? It might pay to let the DirectX 6 installer run during game installation.
Also, you don't mention what graphics driver you are using with the NVIDIA card. There might be a sweet spot for compatibility with regard to the NVIDIA driver version, so you might do some experimentation there.
Reply 2 of 26, by Nicolas 2000
I skip DX6 installation but I let it install DirectPlay which it asks for separately, and that seems to install fine. When I tell it to install DX6 from the installer, it says I don't have enough hard drive space for that (of course I have oceans of hard drive space, I assume it's just poor "onerror" coding in the installer; when I try to install DX6 separately from the game CD it just says that I have a higher version already.) Anyway, when the game did work in the past, I was also running DX7 or higher.
For the Ti4200 I use the V81.98 drivers. The reason for going with these recent drivers is that my PC really did not like the older, "safer" ones causing me to have to do a full Windows reinstall more times than I can count. With 81.98 I finally had no crashes/errors (if I'm not confused with other issues, I think it were nasty VxD errors upon booting W98) and a nice 3DMark score. I can try to roll back to a recommended V40.something (don't know by heart) but I'm afraid it will brick my system *again*. But it might be the cause of the issues, as the Ti4200 is the only truly relevant change in my config compared to when it did work. The only other thing I think about is that in the past I did not have the proper chipset drivers and maybe the game doesn't like AGP 2x or something like that?
Reply 3 of 26, by Nicolas 2000
I installed the 43.45 drivers, and that didn't help. Luckily the pc still works. Setting AGP at 1x also didn't help. Disabling the sound card didn't help.
Reply 4 of 26, by Nicolas 2000
Would it be worthwhile to do a full reinstall of the pc once more and try toca 2 with only the chipset drivers installed, so before even installing graphics card drivers or voodoos? Just as a way of finding the issue.
Reply 5 of 26, by akula65
You mentioned that your original configuration only had 256MB of RAM. Did you try to go back to 256MB, or are you still using 512MB? That would be an easy thing to try before you take drastic measures.
Reply 6 of 26, by Nicolas 2000
I can try that, but it was my understanding that up to 512 W98 was happy?
Reply 7 of 26, by Nicolas 2000
I haven't experimented on the hardware side yet, but I'm now in doubt whether my previous successful install of TOCA 2 was on this PC in its previous configuration, or on a different W98 PC altogether. In any case, TOCA 2 *should* be able to run on this config as it's all quite period correct hardware so the mystery remains.
Reply 8 of 26, by Nicolas 2000
I've checked my chat history: TOCA2 ran on this pc with 512mb and the Rage Pro, but using the voodoos.
So the only difference now is the Ti4200 instead of the Rage Pro, and chipset drivers so some influence on things like AGP.
Reply 9 of 26, by RetroPCCupboard
I just tried TOCA2 on my Win98 PC. No voodoos, just a Geforce Ti 4600. It seems to work fine. Though when I first tried the menu was crazy fast and the physics in game was broken, and very high input lag. Enabling vsync seemed to resolve that
Reply 10 of 26, by Nicolas 2000
Thanks for trying! Hmmm so weird that mine suddenly doesn't want to launch at all. Having the correct chipset drivers should only make it more likely to work...
I'll try with vsync on for the heck of it, but no high hopes there.
Reply 11 of 26, by Nicolas 2000
Vsync did not help, I also only found a vsync setting in the ti4200 software, not separately for the voodoos.
Reply 12 of 26, by Nicolas 2000
Removed all of directx: now dx6 does install from the cd. No difference though.
Booted in safe mode: now it does open the setup screen! To no avail, as safe mode knows no graphics cards.
So it is something that is loaded in normal boit and not in safe mode causing the issue.
Reply 13 of 26, by Nicolas 2000
Could anybody share the setup file that is made after saving setup? Maybe that way it will skip setup and just load the game. I do not have that file as I've not been able to save a setup.
Reply 14 of 26, by RetroPCCupboard
I am not sure what you mean by setup file?
Reply 15 of 26, by Nicolas 2000
It is my understanding that a config file is created in the main TOCA2 folder that stores the games's config as saved from the TOCA settings program. And I assume that when this file exists, Launcher.exe goes straight to the game instead of the settings program.
Reply 16 of 26, by paradigital
From my (limited) understanding, the 512MB “limit” in 98 includes all addressable RAM, including the Video memory.
The Rage would have had a lot less VRAM than the Geforce 4? That coupled with the error message that the installer throws would suggest a memory problem.
Have you tried 256MB of system RAM with the GF4?
Or the R.Lowe patch?
Reply 17 of 26, by Nicolas 2000
I have not tried it with 256 ram yet, but it did work with 512 + 2 voodoo 12mb + rage before. Also, the installer does not throw any error when installing on a pc that is not yet beyond DX6.
I will try the Loew patches.
Reply 18 of 26, by Nicolas 2000
Update:
-I installed the Loew 512MB patch. You were right that AGP memory counts as RAM so I was over 512MB and needed (in theory) the patch anyway. It didn't help though; still the same eightfold error when the game tries to open the setup menu before the first time you play the game.
-uninstalled the Geforce Ti4200 from Windows: now it does launch the setup menu! However, as the Ti4200 is not installed -and I assume because of the Voodoo's being piggybacks also out of action that way-, I could not select any graphics card from the setup menu and as a result when I pressed "play" it kept opening the setup menu to let me choose a graphics card. As soon as the Ti4200 driver is reinstalled, same problem as initially.
So while this does point to the Ti4200 being he apparent culprit, it doesn't solve my problem. Would there be any hope in trying out some of the many Ti4200 drivers out there? Other ideas such as AGP speed, AGP aperture size in BIOS...?
Reply 19 of 26, by Nicolas 2000
I might try to uninstall the Geforce as deep as possible, and then reinstall it with 45.23 which apparently is very compatible and see what happens. Though I have already tried installing 43.35 and that didn't help. I've also tried setting AGP speed to 1x and that didn't help...
