First post, by Mourales
Hello everyone!
I'm currently working on a project with a 486 and I'm experiencing problems finding the standard AT MB standoffs for it. (I attach a photo)
I've been trying hard to find a seller in Europe or on Aliexpress, but so far I haven't had any luck. The regular non slide-in versions (with no peg) are fairly common, though.
I did find some options in the U.S., but shipping costs are insane...
Thanks in advance for your help!
Reply 2 of 6, by Mourales
Yep! Thank you very much! I
Reply 3 of 6, by Yoghoo
To add to that. If you 3D print them I would suggest using PETG. As PLA breaks very easily (at least that is my experience with this model). Also you need support and that can be a pita to remove.
Reply 4 of 6, by Mourales
Thanks a lot!
Reply 5 of 6, by Linoleum
I ran into the same problem and ordered some from Aliexpress for $3-$4: https://www.aliexpress.com/item/4001241127659 … .bd1d180286gV5p
However, I had to add some double-sided tape at the bottom... So that's the cheapo alternative.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 6 of 6, by Mourales
Thank you ! I will try that idea too.
