First post, by butjer1010
Hi to all,
I have one question before i can do some damage 😀
Can i use WinFast Titanium (2842) on AGP2x slot with 3.3V?
https://theretroweb.com/expansioncards/s/lead … infast-titanium
Thanks
Hi to all,
Thanks
I’ve used mine on AGP 2x slots without issue.
paradigital wrote on 2025-08-03, 07:36:I’ve used mine on AGP 2x slots without issue.
Thanks man!
Wasn't sure, so better ask than destroy 😉
What mainboard do you have? Some older boards can't deliver enough power since the VRM to the AGP slot can't supply enough power (and get very hot)
has all kinds of stuff
This card is in auction right now, for small amount. I will try to bid for it, and i was asking if i can use it with older boards i have. Like Asus K7V (Slot A) or MSI MS-6119 (slot 1)...
One of the boards I have used mine in is a K7V with a 900MHz Thunderbird.
paradigital wrote on 2025-08-03, 09:08:One of the boards I have used mine in is a K7V with a 900MHz Thunderbird.
Great, it will work than 😀
