dbellue1 wrote on 2025-08-09, 16:37:
Hey Major Jackyl, I see you have a similar system to mine with the MSI motherboard and a Intel 12900K. I wanted to ask what kind of cooling solution do you use. I was thinking about going with the Artic freezer 3 or an Noctua fan. I am Leary of changing out a AIO every three yrs because of the loss of fluid in the radiator. If I mess it up during install I am worried I could damage the motherboard.
I use a Nzxt Z73 of an older generation. It's probably 3 years old and still no liquid loss. It's not oriented the best, so I will know if it starts having issues, but under load it only gets to 40C on a hot day (P-cores running@4.2Ghz, e-cores@3.6Ghz.) If it ever fails. I'll replace it with a Noctua NH-D15, because I use them elsewhere; they are the most powerful, solid coolers you can buy in the modern-age.
The attachment 20250811_164731.jpg is no longer available
That Micron looks pretty sweet so far! Vibra16C is a good chip and made BETTER with that CT1920. Finding a USB PCI card would be the icing on the cake. I use floppies and CDs still. The disk with "NUSB33e.EXE" (USB install package for w98, english) is the most used during setups, since most of my computers have USB.
If the inside is very dusty, the inside of the CD drive could be, too, as fans will try to pull in air from anywhere. The drive might need a cleaning and it'll be golden.
The Microns I've collected have definitely grown on me. I have three same, but different ones, and one newer one, with S462. All very simple and definitely hit that nostalgia spot nicely.
The attachment 20250811_164624.jpg is no longer available
Damn, it was more than 15 years ago now, I worked as a scrapper for a few summers and unfortunately destroyed quite a few of these. I kept parts from them, though. Memory, CPUs, etc. (how I got the blue heatsink) Dude didn't want me taking ANYTHING, every penny went right into cigarettes... This is what made it worse. Some of these are mostly plastic, too and circuit boards paid $0.04 per pound, so they weren't even worth the scrap.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
