First post, by uniQ
Hi,
I recently bought a PicoMEM card for my old Commodore PC10-III family computer for future upgrades and overall convenience.
Currently, I'm using a painstakingly transferred DR DOS 5.0 installation from my old MFM hard drive, running via a CF card using an XT-IDE adapter.
I'd now like to transfer this installation to the new PicoMEM card.
My question is:
What's the best way to go about this? I've already tried creating a suitably sized IMG file via PicoMEM and injecting the CF card's data into it,
but the system no longer boots from the IMG that way.
My Retro Systems
Reply 1 of 5, by Jo22
Hi, maybe Win32 Disk Imager can help? 🙂
On Linux, there's GNOME Disk Utility, it can restore/save drive content from/to images, too.
Reply 2 of 5, by Yoghoo
Did you make a disk image so that the boot record is also transferred? Just copying data does not work.
If the data is readable on drive C: when booting from a DR-DOS 5.0 boot floppy then you can do "SYS C:". Then booting should work again.
Reply 3 of 5, by Jo22
That's a good idea. Because XT-IDE and PicoMEM may use different LBA translation. I didn't think of this before.
Reply 4 of 5, by uniQ
I tried several cloning and HDD imaging tools but the PC10-III just won't boot.
I ended up taking the longer route via PCem, connected the PicoMEM IMG, reinstalled DR DOS 5.0 and copied my data using WinImage.
Now it runs on the Commodore as well. 😀
My Retro Systems
Reply 5 of 5, by vetz
I use Disk Editor from the Norton Utilities package:
Object -> Drive -> Physical disks -> Hard Disk 1 (your MFM harddrive)
Object -> Physical sector -> Cylinder: 0, Side: 0, Sector: 1, Number of sectors: maximum
(cursor at the beginning) Edit -> Mark
Press "End" to select the entire disk area
Tools -> Write to -> to a File... (make sure you can write to a second harddrive, zipdrive or network location)
.img file can then be opened up in utilities like WinImage or used on PicoMem
