First post, by megatron-uk
Trying to find an mSATA/SSD solution for an old Dell Latitude X1 I've just dug out of my "box of old rubbish".
It seems to work quite well - no damage or faults, the battery holds (and charges) to a reasonable level... but it still has fitted the old/slow 1.8" 50pin PATA drive (working for now, albeit very slowly, but I don't know for how long). I'd like to swap it with a SSD, in this case I'm hampered by the form factor but would have thought a 1.8" to mSATA adapter would have been relatively easy to find. No such luck it seems!
I was able to track down a 1.8" to CF adapter quite easily, and that will get me going for now and allow me to remove the old 1.8" drive. Ideally I'd prefer to fit a proper mSATA SSD module.
Does a direct 1.8" 50pin PATA to mSATA converter exist?
https://www.target-earth.net
