First post, by HomeLate
A long shot, but I recently found a Diamond Trackstar 128 without any cables. The card was installed in a Tandy 1000 SL but that system is long gone. Unfortunately the cables which came with the card, are nowhere to be found.
I know the card needs a copy protected floppy disk to get the card to work.
I do have an Apple II floppy drive but not a 360kb floppy drive. Would the card work if I launch the Trackstar utility software from a PC with 360kb floppy drive and boot the Apple II disk from the Apple floppy drive?
