First post, by Rafael Oliveira
When l Try To Access The Windows 1.0 DR5 Build Floopy On PCem l Get Sector Not Found Reading Drive A Abort, Retry, Fail?
Does Any More Have Ideas To Solve This Problem ? It Would Be Relly Appreciated
Sorry l Can't Edit l Mean It Would Be Really Appreciated
Hi, it's just an idea but did you try accessing it from MS-DOS 2.11 too?
Because, MS-DOS 2.11 is from 1983 and can't handle newer floppy drives without help.
Which in turn means it assumes older floppy capacities from the time.
So if PCem (for whatever reason) reports a "wrong" drive/drive geometry, MS-DOS 2.11 won't use it but sticks to its period-correct defaults.
Could be useful for this 8 sectors per track vs 9 sectors per track difference.
Can you access all the other floppy disk image except for this one?
VCheck+ Portable Antivirus for DOS
Main: https://archive.org/details/VCHECK/
Updated! : http://old-dos.ru/index.php?page=files&mode=f … =show&id=103705
Under PCEM - it's a floppy image?
How did you make it?
What exactly is the image size?
If you have the original diskette, I stringly recomend making an image of it using my
ImageDisk (available on "Daves Old Computers") - this will perform an analysis and
determine exactly what the format of the duiskette is!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Sorry for being inactive l think l will use MS-DOS 2.22
