First post, by cansting
Hi all
I got a new hdd WD800 (80GB) unfortunately my pc cant discover it - bios is thinking for a while and finds nothing
Apparently there was a fix in Bios version 1011 to address issue with disks bigger than 32GB
Initially I started with Bios 1008, after finding this info I flashed it to 1012 but no luck, flashed it to 1014.003 - same
Tried different cables (40 and 80 wire) making disk only one on the ribbon, master/slave - nothing
Motherboard is Asus p2b rev 1.10, currently with bios 1014.003, other 2 disks i have there (20GB and 10GB) are discovered with no issues
Diak gets successfully discover on my other pc with Tyan S1854 MB (Apollo Pro 133a)
Appreciate any hints on that!
EDIT: Found the culprit - jumper set to "master" messes everything up, even of the device is the only device connected...
Current vintage config:
InWin A500 with Asus P2B (440bx), Pentium II 450, 512MB PC100, Creative 3D Blaster Annihilator Pro +Diamond Monster 3D II, YMF719E-S+ Diamond Monster Sound MX300
