PCD-5ND Display options
First post, by hs4500
Hi dear people out there,
Currently playing around with a PCD-5ND. Awesome device, great for DOS gaming.
I read online that it came with multiple display options. There was a 640x480 version and a 800x600 version with 65k colors.
I have a 640x480 version with 256 colors installed. Pretty old and not bright anymore.
Does someone has the 800x600 display and can share the part number? Or does someone have the 640x480 screen that supports more than 256 colors and can share that part number?
With the part number I could then look up alternatives that fit.
Your help is much appreciated!!!!
P.S the part number can be found below the display, means once you life the display out of the base, the sticker is right below.
Cheers
