SB0060 IRQ Woes
First post, by Gopher666
Hey,
I have this card in a multiOS box, XP/Linux works flawlessly even without a driver, since I went through some trouble to try to get DOS 6.22 and Windows for Workgroups 3.11 running on this machine I would like to have sound in them as well but now after a day of pain I start giving up.
The issue is not with the card being broken, it is the usual DOS IRQ problem. By default if they are allocated automatically (and all unnecessary peripheries are disabled: USB/internal audio/com ports/LAN cards) I get this IRQ allocation:
https://i.ibb.co/Y4jb3gTs/IMG-20250820-202636-180.jpg
https://i.ibb.co/k6J5PRjq/IMG-20250820-202658-364.jpg
In this case as you can see the driver will not even load.
However I tried to trick around with putting the IRQ allocation to manual, putting the card to another point etc until the point both IRQ 5 and IRQ 7 are free.
I'm not an expert on this but as I recall this card loves IRQ 5. It is probably using one IRQ for the card itself and one for that SB16 emulation.
In this case the driver will load but none of the games will work.
https://i.ibb.co/pjGLqcNg/IMG-20250820-202114-764.jpg
https://i.ibb.co/qM6vcbSV/IMG-20250820-202450-072.jpg
https://i.ibb.co/d4gxxzmd/IMG-20250820-202342-250.jpg
https://i.ibb.co/5hkSPGn9/IMG-20250820-202332-984.jpg
https://i.ibb.co/5x52pG0w/IMG-20250820-202206-522.jpg
https://i.ibb.co/7trKFvWx/IMG-20250820-202148-769.jpg
I have another machine (although that is with an SB0100) MSDOS6.22, same driver, card is on IRQ 12 it works just fine.
Any ideas what else can I try?
Thanks
Reply 1 of 7, by Linoleum
Yeah, you're trying Sound Blaster on "hard mode" with a Live! on DOS... The card itself can have an IRQ of 10 , 11 or 12. Leave the card pick whatever it wants! However, you need to make sure IRQs 5 or 7 are free for the SB16 emulation. Same goes for DMAs (1 and 5 usually). Reserving them (or setting them to ISA) in the BIOS like you did is the best approach...
Most importantly, please attach pictures to your message instead. This will help a lot! 😉
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 2 of 7, by Gopher666
There is absolutely nothing, zero, nada for DMA settings in the BIOS. Shouldn't that be automatically allocated by the programs anyway? When SBECFG says DMA 1,5 allocated it should be allocated.
With the IRQ all the fiddling around what I can do is I put it in reserved or NOT in this BIOS (it's kind of new as this is already an ATOM CPU based system).
Anyway I can load the card with other IRQs after all if I put it into manual mode eg IRQ 11 worked but the port what it assigns is a weirdo, this DF00, that is on my other machine 0x300. Can't that be the issue?
Reply 3 of 7, by zyga64
Hey, you can attach images to the post as attachment.. Hosting on imgbb doesn't work good 🙁
All I can see in your post looks like this:
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 4 of 7, by DudeFace
Gopher666 wrote on 2025-08-21, 07:55:
what are your systems specs? (motherboard/chipset). also none of your pics are displaying, you mentioned an atom cpu , i have an early atom board with an intel 945 chipset which isnt compatible with sound in dos, even if you manage to install the card and it doesnt lock up the system you will have no sound, only option is to use SBEMU instead of soundblaster drivers, though you will lose general midi.
Reply 5 of 7, by zyga64
DudeFace wrote on 2025-08-21, 11:26:
(...) only option is to use SBEMU instead of soundblaster drivers, though you will lose general midi.
Not anymore: VSBHDASF: Fork of VSBHDA with Soundfont support
Reply 6 of 7, by Gopher666
The marvels of modern technology, that they give u a hard time sharing an image 😁 Sorry for the blurry images, my phone is dieing, they are still readable.
Ok let's start this from Square 1:
Everything was put back to automatic, unnecessary peripherals such as integrated LAN cards, COM1/2, integrated audio are disabled.
The attachment IMG_20250824_204011_311.jpg is no longer available
Here you can see a lot of thing loves to share that IRQ 7 so this time I moved the SB16 emu with SBECONFIG to IRQ 5 prior. The USB is still holding IRQ5 here.
Interestingly the card initialization succeeds:
The attachment IMG_20250824_204420_706.jpg is no longer available
As you can see the main card gets that weird DF00 port.
I try to configure it in games like this:
The attachment IMG_20250824_204555_542.jpg is no longer available
I tried all card types already from SB16 to SB 2.0 in Duke, it's the same in other games, says the soundcard cannot be opened.
So I go to the BIOS and PUT IRQ5 to reserved:
The attachment IMG_20250824_204700_000.jpg is no longer available
Now it should be free:
The attachment IMG_20250824_204732_887.jpg is no longer available
But nope, it does not make a slight difference. I hope you got some good idea to resolve this because I would really love running DOS/WFW311 natively on this box.
Thank you for the ideas!
Reply 7 of 7, by DudeFace
zyga64 wrote on 2025-08-21, 12:13:
i've not tried this out myself so not sure how well it works, with a decent soundfont its gotta sound better than the lives midi.
