I/O Plate
First post, by DustyShinigami
Hi
After the issues with the previous ATX case I had, which I had no choice but to get rid of and get a new (old) one. Thankfully I won it for a decent price. I now finally have one that has connected LED and power/reset cables how they should be. Plus, this one is much bigger with additional bays for CD drives, floppy drives and the three HDD drives I need. It even has a PSU with it and additional fans for extra cooling. 😀
However, one thing that is missing is the I/O backplate. The question is, how would I best tackle this problem? Because I'm guessing, as usual, there isn't a one size fits all. This motherboard - https://theretroweb.com/motherboards/s/abit-ab-be6-ii - doesn't have that many ports/connectors, to be honest.
The attachment IMG_4482.JPG is no longer available
Sadly, this ATX case is completely unknown. There's no name brand or any indication about who made it.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 1 of 12, by Yoghoo
If you have a 3D printer you can design and print one. Did that many times in the past. There are also a lot of pre designed models available on Thingiverse, Printables etc.
Else you can look at Aliexpress or so for a closed one and cut the holes yourself. Or try one from another motherboard.
Reply 2 of 12, by CharlieFoxtrot
Many backplates from roughly the same era fit with several motherboards. I have used same IO plate with different motherboards.
If you can access 3D printer, that is one way. You can find designs in printables or thingiverse. There are some that are designed specifically for certain MB, but then there are blanks and meshes, where you can cut or CAD your own holes.
Reply 4 of 12, by The Serpent Rider
This is a standard ATX layout which all early ATX motherboards were shipped with, so any standard plate will work.
Reply 5 of 12, by Major Jackyl
If you go the 3D print route, I have this one in my collection:
The attachment ABIT-BE6.PNG is no longer available
The attachment ABIT_BE6.zip is no longer available
I've been lining the backs with foil tape lately and it makes them feel more realistic (and actually shield).
Shponglefan wrote on 2025-08-24, 19:25:
I buy spare backplates from Ebay. You just need to find one that matches the layout of the motherboard components. Most of them are pretty standard.
These are indeed some of the most common backplate, not too hard to spot, even in a large pile.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 6 of 12, by DustyShinigami
Thanks for the suggestions everyone. Sadly, I don't have access to a 3D printer. Yet. It is something I'm interested in though as I do character modelling and sculpting. If it is fairly standard and easy to find, that's good. Reassuring. I'll take a look on eBay and AliExpress and see what I can find. 😀
OS: Windows 98 SE
Reply 7 of 12, by DustyShinigami
Hmm. Can't say I've been having a lot of luck finding one. Most that come up have a lot of holes for the various ports/jacks. Finding one for this specific model, which only has seven, is proving tricky.
OS: Windows 98 SE
Reply 8 of 12, by PC Hoarder Patrol
DustyShinigami wrote on 2025-08-25, 16:36:
This one?... https://www.ebay.co.uk/itm/126713871485 (not my listing)
Reply 9 of 12, by DustyShinigami
PC Hoarder Patrol wrote on 2025-08-25, 17:22:
You utter legend! Thank you. 😁
I guess my searches were too specific. I was typing in the motherboard model followed by I/O plate. Or Abit I/O plate. :p Less is more, I guess.
OS: Windows 98 SE
Reply 10 of 12, by DustyShinigami
Only snag though, is that first image doesn't appear to be assigned to any particular model. Going through the ones that are available in the drop-down list, they're all the wrong ones. So I'm wondering if that first image is to a model that's sold out. I'll try reaching out to the seller.
OS: Windows 98 SE
Reply 12 of 12, by DustyShinigami
maxtherabbit wrote on 2025-08-25, 18:41:
bit expensive but what about this one
https://www.ebay.co.uk/itm/157143746603
Ooh. Nice find. Thanks. Yeah, it is a bit pricey for what it is. I'll see if I get a response from the other seller first, but if not...
OS: Windows 98 SE
