First post, by Gelip
Hi.
In WinXP I use nircmd.exe and this Regedit settings:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\shell\Nircmd]
@="Insert"
[HKEY_CLASSES_ROOT\Drive\shell\NirCmd\command]
@="nircmd cdrom close %1:"
I want to get the same on Windows 95. I downloaded the old version of nircmd.exe 1.70, copy to WINDOWS folder and in MS-DOS mode to close CD-ROM tray as I follow the command:
nircmd cdrom close e:
I make this entry in regedit:
The attachment regedit.png is no longer available
but after right-click on the CD-ROM icon, the My Computer window in the context menu is new entry "Wsuń" but does not work:
The attachment wsun.png is no longer available
The attachment error.png is no longer available
Reply 1 of 3, by Grzyb
First, you have "nircmd cdrom close %1:"
Next, you have "nircmd cdrom close %1"
The colon seems to make a difference...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 3, by Gelip
Yeeeeeaaaaaa, I found a professional solution for Win95 and WinNT 4.0 😀 😀 😀
How to Add “Insert” Option in CD/DVD Drive Context Menu in Windows?
  • copy cdeject.dll to C:\WINDOWS\system32 in Win95 or C:\WINNT\system32 in WinNT
  • apply registry settings from appropriate files: in Win95 (Insert95.reg) or in WinNT (InsertNT.reg)
  • now in the context menu of the CD drive there is an Insert command that closes the open tray
The attachment InsertCD_Win95.png is no longer available
It works !!!!
The appropriate registry files are attached in InsertCD_95_NT.zip file.
