First post, by hydrogen18
I've recently been trying to get a Pentium 4 build running again with an AGP slot and graphics card. The good news is I found one machine in the attic space at my parents house that I think I assembled that seems to work.
I also picked up a huge amount of parts for very little money from an estate sale of a guy who used to run a desktop PC store. His business apparently spanned around 1991-2015 based of the parts available. So for this I started with these parts. I am hoping someone can suggest a next step for troubleshooting or spot what may be my problem
Pentium 4 3.0 HT - SL7PM stepping
Geforce 4 mx 440 graphics card
Platinix 2PE/800 Pro-6Al motherboard - seems also to be called a P2P3/800 pro. All caps on this motherboard are visually OK. It was still sealed in the OEM packaging so this is presumably "new"
Memory - 1GB of DDR Pc-3200 , I am just using one stick for now. I actually have 2 sticks.
I put in a brand new CR2032 coin cell on the motherboard
Power supply is a DELL 250 watt unit that is era -correct
I am booting from Windows XP integral edition disc via CD-Rom. Thankfully I found a bunch of DVD & CD drives at my parents house still. At least a few are fully functional
The CPU cooler is a typical OE type AVC unit that uses the normal retention mechanism. All aluminum design with a 60mm fan on it
for the hard drive I use an IDE -> SATA adapter to use a Patriot 128 GB SSD. I am using this same configuration on the other Pentium 4 machine without issue.
First problem - BIOS interaction is all kind of weird. When I do "Save And Exit" it saves but never exits. It does save if you power cycle the machine, so whatever
Second problem - I cannot install Windows XP successfully. Once I got Integral edition to install but it was crazy broken and did not do anything useful. At this point I notice my CPU is idling at 62 C. I try a bunch of stuff including re-applying thermal paste, cleaning heatsink, etc. Nothing really helps. Eventually I decide the CPU is problematic, it was $9 from ebay
I order and install SL79L stepping CPU off eBay. No improvement to thermals whatsoever. I decide the fan is over 15 years old, so I remove the CPU fan and rig a 1200 CFM blower pointing at the heatsink. This gets the CPU down to 55 C idle in the BIOS. This still is crazy high. At least when the installer is running, I can touch the CPU heatsink without instinctively pulling my hand away. Still cannot install windows, usually cannot even get the installer to start up without BSOD or just locking up.
In BIOS I lower the clock speeds to minimum and disable L1/L2 CPU cache. CPU is now at 2 GHz. Still cannot get Windows installer to get past the first screen, just BSOD.
I swap for another memory stick, since it could be the issue. No change
I swap the power supply for a modern Corsair 650 watt unit. No change in behavior
So it seems I have two problems, probably related: CPU temperature is way too high & also the system is unstable. My theories for causes are
1. Motherboard VRM is somehow defective and although it reports one voltage, is sending the CPU something way higher. I guess I could pull out my o-scope and check this
2. All the memory I've tried is bad - seems unlikely that bad memory is causing high CPU temperature
3. Northbridge has some issue or problem? I think on this era the memory controller is still on the NB if I understand the architecture
Is there anything else here I should check? I remember buying Pentium 4s from this era new - 50 C was considered high temp under load. My total investment is about $35 USD here so far and I do have the other functional Pentium 4 machine.
