First post, by stanwebber
i recently acquired a set of 5 industrial 1gb cf cards and have been installing various os's for my nec versa p laptop. thus far i've installed win95 rtm, nt4 sp6, win98 fe and win2k (no sp) on each respective card. all run reasonably well even with only 40mb of ram, but my secondary goal of getting a pcmcia bcm 4306 wireless card working has eluded me. i thought win2k would be a slam dunk as i have this wireless card working in a cardbus laptop, but win2k just flat out has compatibility issues with the pcmcia controller in the versa p and there is no remedy. since i have 1 cf card leftover i thought i might try a flavor of bsd, if only for the novelty since i have never worked with it before.
before someone suggests linux, i dual-booted dos on all my installs and can access a damn small linux image using loadlin. the problem with linux is that ndiswrapper does not support pcmcia cards whatsoever and later 2.6 kernels with b43legacy driver modules don't support my card's device id and it's not possible to inject unknown id's on the pcmcia bus as it is with pci (bsd might very well have the same restrictions--i don't know).
given these considerations, would someone please recommend an older flavor of bsd for a vlb, isa (no pci bus) pentium 75mhz laptop with 40mb of ram and no cdrom, but has dos access to floppy & pcmcia storage. i would ideally like something with a graphical desktop and a kernel new enough to support a bcm 4306 wireless card if possible, given my system's limited hardware specs.
Reply 1 of 11, by zb10948
I am a long time user of FreeBSD (since version 4) - you're unlikely to find what you want on FreeBSD side. The basic system is not powerful enough to run a FreeBSD version that supports that PCMCIA network card, with a X GUI.
40MB is about the resident size of basic FreeBSD 4.4 install (sendmail and other stuff turned off), with X in 640x480 and Windowmaker (a low footprint but full window manager).
With that amounts of RAM you would look at FreeBSD 2.x or a corresponding NetBSD version from circa 1995 (its early on in libre BSD life so these two share a lot of common code). Note these early versions might have no ports or just a handful of them, so what you would be working with is a POSIX X11 workstation with 5-15 MB of RAM available depending on how less RAM hungry those first versions are compared to circa Y2K 4.4R.
Btw if by DOS access you mean accessing floppy and HDD via BIOS, early FreeBSD will just do that.
Reply 2 of 11, by stanwebber
the comment about dos access to floppy & pcmcia storage was to highlight the available routes for install media.
Reply 3 of 11, by jakethompson1
Are you sure that CardBus cards are even supposed to work in pre-CardBus PCMCIA slots? I don't think so
Reply 4 of 11, by stanwebber
it's a 5v 16bit pcmcia card. i just had it working under win2k drivers in a cardbus slot.
Reply 5 of 11, by zb10948
stanwebber wrote on 2025-08-25, 22:35:
I was responding mostly to the above. Install media is irrelevant, if you use CFs you're able to make the install on a modern PC via emulator.
If your goal is Unix-like system that supports your wireless card and performs OK on that computer, BSD is not it. If Linux is not it, then I guess you're out of luck.
I'm pretty sure, but we can double check that, the driver for your card became available in FreeBSD 7 age. This was contemporary version when I got my brand new Q6600. You don't want to run it on a 40 MB 75 MHz P5.
The driver - for sure - was not around when versions fit for your computer were new. These are only first FreeBSD and NetBSD releases. They have XFree86 - they do not have ports and packages.
To not go to long lengths here, early BSDs are not fit for x86 desktop. They fit for x86 server running standard Unix services or older proprietary Unix stuff.
I've long thought what to use on my Pentium 100 with 48 MB RAM and the best solution I found is loadlin into Slackware 9.
Reply 6 of 11, by jakethompson1
As I'm also into systems of this era, it's worth noting that that Slackware 7.1 was the last one to come bundled with XFree86 3.3.6, which is relevant if you're using one of the many cards that didn't make the cut for 4.0 (including most things ISA or VLB but also some early PCI)
Reply 7 of 11, by the3dfxdude
jakethompson1 wrote on 2025-08-29, 23:57:
These same Xservers are included in pasture/ all the way through Slackware 10.2. I do kind of wonder how useful they are at giving proper hw support that was lost in 4.x.
Reply 8 of 11, by jakethompson1
the3dfxdude wrote on 2025-08-30, 02:01:
Yes, but xf86config is missing from /pasture (they must have thought you'd be carrying your XF86Config file forward from 7.1)
Reply 9 of 11, by the3dfxdude
jakethompson1 wrote on 2025-08-30, 02:24:
The README says, install the packages from /pasture on top of XF86 4.x. That would mean you should still have the examples and xf86config command. But if that is somehow not compatible, then the README further goes on to say, you still have the xset package that you can use to create a config using XF86Setup.
Reply 10 of 11, by stanwebber
thanks for the info on the bsd kernel modules for the bcm4306. it's a shame i can't get it working under any os for this laptop. it's an oddball 802.11g pcmcia card (non-cardbus)... perhaps the only one in existence. i tried asking for device id support to be added on the b43legacy developers mailing list, but it seems to be long abandoned.
Reply 11 of 11, by zb10948
If you need a quick intervention on the FreeBSD source like adding IDs to a driver I would be able to do that.
