First post, by adegn
Hi there
I want to know more about the compression, checksums and file table of award bioses - so I grabbed the source code of Awdbedit. I have converted it to a Visual Studio 2022 solution and made it build. Now, I got to the point where the program starts up - but without menu and toolbar. I've been debugging for some days now, but I can't find the reason why these are missing. Any of you guys out there with C++/Mfc skills, who can find the reason and want to give me a little bit of help?
https://drive.google.com/file/d/1UOKWTb4e38TQ … M2w04scYzIFvfsO
For the plugins to work, rebuild solution. Ignore the error regarding the missing awdbedit.lib - it will be there when building again. After that start the debugger.
