Heh. GCC gross compiler, rather. Compiling GCC7 took 6 days on my Power Mac (via macports)! 🥲
Edit:
But, initally I want it in its slowest configuration to see what I can make it do. I like a challenge. Lol.
+1
I read the Sanyo MBC-550 and 555 was among the slowest IBM PCs, btw.
It had a custom graphics chip with partial CGA compatibility.
An CGA/memory board and a special boot-up DOS diskette was available as an upgrade.
Together, they made it mostly IBM PC compatible; good enough to run MS Flight Simulator.
It just comes to mind, because of challenge.
An Sanyo emulator is maybe available for testing purposes.
Videos:
https://www.youtube.com/playlist?list=PLGt6Ig … O8Ue2wMryQtWNam
What's interesting about the 8088/8086 era is that there are so many obscure, yet beatiful systems.
And with a little, reversable V20/V30 upgrade they can be made compatible with 90s era software, even.
What comes to mind are the Rainbow 100, Alphatronics PC16, the c't-86 computer, NCR PC4..
PS: For sake of curiosity, you may also have a look for PC-Ditto.
It's an IBM PC emulator for Atari ST, which was available since 1986 or so.
The first version emulated an entire IBM PC with CGA graphics in software.
It was very slow, but actually usable to play slow-paced games and run a few business applications.
I myself played some graphics adventures that used CGA graphics, such as Fahrenheit 451. It was "ok" actually.
If I had to use a copy back in the day, then I would have switched the Atari Mega ST to 16 MHz, maybe.
Or installed an accelerator card, not sure. It would have helped the emulator.
I still use it for compatibility testing purposes, besides DOSBox and PCem.
Such as here: Re: Olivetti/Logabax/AT&T/Toshiba 640x400 hi-res graphics mode
PC-Ditto had issues with text-mode (the MDA type), so I used CGA graphics for text in QB.
The supplied utilities of Ditto do speed up text output on DOS and add some functionality.
They speed up utility is also usable on real XT class hardware.
PC-DOS 3.30 and MS-DOS 6.20 ran just fine last time I checked.
Re: Minimal hardware/peripherals to emulate for Windows
https://www.youtube.com/watch?v=ytM-uznCZc4
Oh, and then there's another one. The BBC Master 512.
It was an upgraded BBC Master 128 with an 80186 co-processor card.
It ran DOS Plus and GEM, had a mouse too. BeebEm emulated it at one point (older releases).
There's CGA emulation, which re-directs graphics to the BBC's native video modes.
Quite interesting. The palettes have different colours..
https://www.youtube.com/watch?v=V15vk2043mI
PS: What comes to mind about PC/XT class hardware:
MS-DOS 2.11 was very lightweight, easy to use and could use Unix style separators! It's also in ROM of Tandy 1000 series.
However, it wasn't the fastest when it comes to i/o and had limited floppy support.
Early emulators such as PC-Ditto thus had recommended to use DOS 3.x when possible.
Such as MS-DOS 3.20, because 3.30 wasn't out yet.
I do recommended PC-DOS 3.30, thus. It's more modern than the others, I think.
Compaq DOS 3.31 is another good alternative, MS-DOS 4.01 is a bit memory heavy.
If you're curious about CP/M-86, you may consider DOS Plus 1.2.
It can run both CP/M-86 and DOS 2.x applications and read both filesystems (CP/M and FAT12).
https://www.youtube.com/watch?v=D1v3e-pF4Kg
Multitasking on PC/XT is possible on PC-MOS/386 and Wendin DOS..
https://www.youtube.com/watch?v=zl6dZq0aV2w
https://www.youtube.com/watch?v=LtHNEUEF2Iw
Alternatively, Minix 1.0, ELKS and Eumel can be run, too.
https://6xq.net/eumel/
https://en.wikipedia.org/wiki/Embeddable_Linux_Kernel_Subset
