First post, by mtest001
Hi all,
I want to spin up a UT2003 server to play with some friends, unfortunately I can't get the archive of the linux standalone server.
All the links on this website are broken:
https://www.beyondunreal.com/main/ut2003/ut2003essential.php
https://www.beyondunreal.com/articles/running … 03-demo-server/
A search on archive.org did not bring anything. Same thing with file search in Google.
Thank you for your help.
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 2 of 4, by mtest001
Great, thanks a lot !
Reply 3 of 4, by mtest001
Ok, after a little bit of efforts I managed to get it to work on a modern linux.
It's a 32 bits app so there are a few libraries to be installed.
Just in case someone want to try out, here is the procedure I followed:
sudo apt-get install libc6-i386
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install libgcc-s1:i386
Edit Default.ini:
change reference to the NvidiaLogo.ut2 (use CTF-Face3 for example)
Change the master server to utmaster.openspy.net
Enable webserver:
- Change "bEnabled=" to True
- Add "ListenPort=8080" or whatever suits you (remember that only root can bind ports below 1024 so if you want to start the game server as a non-root user, which you should, use a high number port)
Change Adminpassword ← does not seem to do anything, admin login and password can be set when launching the server see below
Launch the server:
linux32 ./ucc-bin server CTF-Face3?AdminName=admin?AdminPassword=sekrit -nohomedir -ini=Default.ini
Open ports 7777(udp) 7778(udp) and 7787(udp) (and possibly 10777, tbc)
Now I'm going to make a Docker image of this to make my life easier.
Reply 4 of 4, by mtest001
I am done creating the Docker image for Unreal Tournament 2003 server. The Dockerfile is here: https://github.com/googleg/ut2003srv and the image here: https://hub.docker.com/repository/docker/goog … 2003srv/general
Testers welcome !
