First post, by AaronS
I'm trying to find an ideal Nvidia card for Windows 98 for a more modern board that has no AGP, so PCI or PCI Express. I've read that the PCX FX cards cannot go below 6x.xx which is past the point of compatibility with a number of titles, and I think these were the earliest PCIe Nvidia cards. However having a look at techpowerup I found that the NVS 280 had a PCIe release (NV37), which may be compatible with 56.64 at least. Has anyone any experience with this card?
https://www.techpowerup.com/gpu-specs/quadro- … -280-pcie.c1456
I have a 6800 currently which works amazingly well but I prefer something a bit older and more compatible. PCI FX 5500 is probably what I'll end up going with since they're more available, but quite pricey.
EDIT: Hmm actually maybe not, the PCX FX 5900 is NV35 and according to nvidia driver installation inf the earliest mention of it is 61.76
https://www.techpowerup.com/gpu-specs/geforce-pcx-5900.c56
https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
I suppose you would get 8 bit palleted textures but otherwise there's no real benefit over a 6000 series.
