Gateway 2000 P4D-66 Issues
First post, by Tory4
Hey all,
I am 100% new here, been lurking unregistered for a while, feeling my way back around the DOS gaming environment. I was big into DOS gaming with my dad as a kid. He had a Gateway 2000 4DX2-66. I purchased a P4D-66 (similar case, same 486DX2, with the exception of a different MB and PCI support). I outfitted it with 64mb of ram, and it runs a DOS (6.22) only environment. I remember the 4DX had a nice binder book with a MB map, all the circuits and jumpers laid out. If ANYONE has that book for the P4D I would really like to have some copies or pictures of the pages. It would be greatly appreciated.
Long story short I have been feeling my way around this thing. I have it running decently with the exception of a few issues. My biggest issue is some IRQ conflicts. I am trying to use IRQ5 for my sound card (Im unable to the SB16 Diagnose utility says IRQ5 is taken). Im using the system information utility in DOSBench and it says IRQ5 is taken by a LPR2 Port from the BIOS. I open the Phoneix Bios setup and there is a COM1, COM 2, LPT1 but no LPT2. Heres the kicker though... If I disable the COM or LPT ports in the BIOS, they still show up in the DOSBench utility as before.
The quirks of this machine: The machine came to me with a SB16 (CT2230) with a SONY CD interface (the card has jumpers and non soldered connectors for the Hitachi and Panasonic interfase as well. I had it working, it sucked honestly due to ram usage. I got rid of it, sourced a decent speed IDE drive off eBay, and hooked it up using some much lower ram usage drivers. The SB16 runs of IRQ2 which is run off IRQ9 from what I understand. So I have been dealing with quite a few hanging note issues with certain higher CPU usage games (NFS and Rebel Assault II in particular). I purchased a Labway A151A00 card off eBay and it is arriving today. I just loaded the Unisound utility and the SetupSA Yamaha driver onto my CF card hard drive. I would REALLY like to run this card off of IRQ5... I pulled out the SB16 card this morning, I noticed it has jumpers for IRQs for the CDROM but I think it may ONLY be relative to the Panasonic interface. At first I thought maybe that CDROM interface was causing the conflict but after looking at some things I think that may not be it.
I looked at the MB and I cannot find any jumpers to command any ports (i figured this was controlled in the BIOS anyways) but my changes I make in the BIOS doesn't seem to be taking effect on the DOS side. Can anyone give me any advice on clearing IRQ5?
Reply 1 of 22, by dominusprog
Does this board have a Dallas chip? If so, you have to replace or mod it.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 22, by Tory4
dominusprog wrote on 2025-09-02, 16:23:
Yes its modded with a CR2032 battery. Do I need to pull the battery and replace to get the changes to take effect?
Reply 3 of 22, by dukeofurl
Nice. Which case does yours use? Incredibly, over different years, I think you could get a gw2k 486dx66 in any of four cases (with different configurations and different versions of the Phoenix bios). Full AT size horizontal case, large tower, more conventional size baby at case, and mini desktop that was half the height of the conventional size case.
I think the Dallas chip is socketed on the half height mini desktop, and the full size AT one uses only an external battery pack, so you must have one of the others 🙂
Reply 4 of 22, by Tory4
dukeofurl wrote on 2025-09-02, 17:28:
Nice. Which case does yours use? Incredibly, over different years, I think you could get a gw2k 486dx66 in any of four cases (with different configurations). Full AT size horizontal case, large tower, more conventional size baby at case, and mini desktop that was half the height of the conventional size case.
SWEET!! Its the tower but not the super size one with the buttons up top it has the buttons in the middle on top of the fan inlet grate below the drive bays.
Reply 5 of 22, by dukeofurl
Tory4 wrote on 2025-09-02, 17:31:
Cool. I have the full size horizontal one. You can hit Ctrl Alt esc to enter the bios at any time from the prompt and various times during post which is handy, though the bios on mine is very simple and has many fewer options than other ones I've seen on 386 and 486 PCs.
Reply 6 of 22, by jakethompson1
ISA IRQ assignments are somewhat fuzzy and not as straightforward as something like lspci shows for PCI devices.
It's unlikely that you actually have an LPT2: port or that IRQ 5 is taken. MSD guesses that IRQ 5 is used by LPT2: also. It's just because this is the standard IRQ assignment for LPT2: in a PC AT. Further, the LPT ports don't actually use an IRQ when used by opening them as a file and writing to them (as a DOS program does when printing). Instead, DOS uses polling mode I/O. Because polling only needs to take place when printing is happening, it doesn't carry the performance penalty that polling normally has. If it's a Zip drive connected to your parallel port instead of a printer, then you definitely want the IRQ working. So long story short, IRQ 5 is likely free for use by your sound card as you desire.
Reply 7 of 22, by Starcat
Sounds like the BAT486IP. Here is some jumper information:
https://web.archive.org/web/20001019100134/ht … /bat486ip.shtml
https://theretroweb.com/motherboards/s/anigma-p4d-420tx
A BIOS update might help in terms of disabling ports properly. There were different version depending upon the exact part number of your motherboard:
https://web.archive.org/web/20010615190049/ht … s/486desk.shtml
Metropoli BBS has some BIOS images:
http://files.mpoli.fi/hardware/ROM/OTHER/
Hope that helps.
UNIX is a simple, coherent system that pushes a few good ideas and models to the limit.
Ritchie, D. M. Reflections on Software Research. Commun. ACM 27, 8 (August 1984), 758-760.
Reply 8 of 22, by Tory4
dukeofurl wrote on 2025-09-02, 17:38:
Thats awesome! You essentially have the horizontal version of the one my dad had when I was growing up. That crystal scan monitor just completes it so well. Im looking for an anykey keyboard for a decent price (ebay I will find one just getting the bugs worked out first). I have those speakers with the subwoofer but I have them paired with my modern computer I use for sim racing and flight sim. I actually use a SONY BVMD14H5U (broadcast monitor) with a scaler as a monitor. Its so I can hook anything to it and play.
My BIOS is pretty restricted too... I can mess with the peripherals, cashe, SRAM, and a few others. I know some of the stuff is taking effect because when I disable the IDE contorller it wont boot (like it should). Im just not sure what to do about freeing up these IRQs (especially this mystery LPT2 port). I remember dads had the phoenix bios like mine has and they pretty much look alike. Although I cannot remember the features on his because honestly it was 20 years ago... I'm still trying to figure out exactly which MB this is (Its going to be different than the 4DX2 because the P4D-66 has 3 PCI slots and I think 4 ISA slots).
Reply 9 of 22, by Starcat
There was also a troubleshooting utility if you can find it:
https://web.archive.org/web/20010610194755/ht … /bios/486.shtml
Sometimes clearing ESCD can help.
Reply 10 of 22, by Tory4
jakethompson1 wrote on 2025-09-02, 17:46:
Ok that 100% makes sense. This unit has a combo 1.44/1.2mb drive which run off a single IDE cable and a separate CDROM I added via IDE. There arent any other drives or ports. THat being said I got this off a guy who got it out of a storage unit. It was a working computer with windows 3.1 stock Gateway stuff on it. I have no idea what was connected to it in the past. it most likely had some other cards attached because there were a few open (missing metal filler pieces which I replaced) IDE slots.
Heres the kicker on that though. If I try to use the BIOS to mark IRQ5 as used the computer will freeze while it runs autoexec/config at boot. If i mark IRQ5 as free it is fine and goes right through. So there is a conflict somewhere. Im kind of afraid to select IRQ5 in autoexec (by editing it) because if it causes a freeze I cannot undo it at that point. I guess if I have to I can use my modern PC to use note pad to edit it if I have to just to try it out.
Reply 11 of 22, by Tory4
Starcat wrote on 2025-09-02, 17:52:
Sounds like the BAT486IP. Here is some jumper information: […]
Hope that helps.
You sir are the man! Thank you!
I am going to put my new sound card in tonight then I am going to try to put more into finding out what MB this is. If I cannot figure it out I will post pics tomorrow.
Reply 12 of 22, by dukeofurl
Tory4 wrote on 2025-09-02, 17:52:
To get into the details, its the vivitron monitor, which was a rebranded sony trinitron. This particular monitor, and keyboard, and speakers, were not sold yet when this 486 was being sold in 1993, I think they are more circa 1995/1996 accessories, but I already had these accessories for a later pentium gw2k that I own and there's only so much money I'm willing to spend on this stuff 😀
If you get an anykey keyboard (or certain other gw2k keyboards of the mid 90s), it can be common for them to not register certain button presses due to degradation of foam that serves to apply pressure to connect the keyboard flex circuit to the cable. There is some discussion here about fixing this issue by wadding up some tissue Re: Fixing up a Gateway 2000 AnyKey keyboard
Here's also an upgrade to the phoenix bios for certain gw2k 486s that recently came to light. Not sure it will be applicable to your machine though, it came with the older full size gw2k tower that had a micronics motherboard, not sure if yours would have a different mobo or bios revision. https://archive.org/details/install_20250814
Reply 13 of 22, by Tory4
dukeofurl wrote on 2025-09-02, 18:06:
To get into the details, its the vivitron monitor, which was a rebranded sony trinitron. This particular monitor, and keyboard, […]
I know the speakers you are correct because I got mine from my Grandad who had the HUGE P5 case. Thanks for the info on the anykey, i remember that happening but nothing beats the feel of that keyboard (IMO). I used that keyboard until around 2005 when it finally died on me.
Reply 14 of 22, by Tory4
Alright I am going to get this card installed and get it going then I will work on figuring out what this motherboard is. I don't want to fry it so I was to be 100% sure when I install a new bios update.
Reply 15 of 22, by Tory4
Alright I believe its the Anigma 486 PCI board.... Looks like its very poorly documented besides this:
https://theretroweb.com/motherboard/manual/ba … 00046841452.pdf
At POST it shows Phoenix BIOS Version 4.04.7 Looks like that might be the latest verision for that MB. There are no pics of that board on the archive but the description of it is the only one close to my board.
Reply 16 of 22, by jakethompson1
Tory4 wrote on 2025-09-02, 18:00:
I like HWINFO for DOS (author is on this forum); it can parse the ESCD table and other metadata from the BIOS, and hopefully give you an idea what ISAPNP devices it thinks it has
Reply 17 of 22, by Tory4
jakethompson1 wrote on 2025-09-02, 18:55:
I just downloaded it, I am going to add it to my CF HD right now.
Reply 18 of 22, by Tory4
I think I may have figured out part of the issue.... I need to look through it but this motherboard didnt have any battery besides the dallas clock... Im very sure my dad's earlier board had a battery pack wired to it... This board I do not think it does (Im assuming it was removed)... There is no coin cell besides the one I wired to the Dallas clock.
Im pretty sure thats my issue with it not forwarding changes from the bios. Any thoughts?
Reply 19 of 22, by Tory4
Alright! Got good and bad news. I tried the HWINFO application and that thing is awesome! I was using the DosBench system info application before and it was showing all the com and LPT ports occupied in their set IRQs. So I have had the LPT ports 1 disabled and never had a LPT2 hooked up. Both are disabled according to HWINFO.
So I installed my Labway A151A00 card, I ran Unisound first to make sure it saw the card, it did it set it at IRQ5 and it did work (I used doom to figure everything out). Here was the issue it was super noise ridden I would get random slight beeps and the sound fx would not work. After many config changes (by using set blaster in autoexec.bat) I began to have IRQ conflicts. Finally I ran SetupSA (IRQ2 is not available in this and setting it to IRQ9 and setting it to IRQ2 in doom did not work). I have LPT1 disabled (I have no use for a printer on this machine) so I went ahead and tried IRQ7. It worked and it worked well!
I re configured most of my games last night and I haven't had any issues.
This morning I deleted the command in Config.sys to start the TSR for the driver for the card to see if Unisound could just configure the card as it is plug and play (trying to keep my ram as clear as I can). So far so good there.
Games I have had success with:
Doom
Star Wars Dark Forces (no stereo reverse needed)
Prince of Persia 1 and 2
Mickey ABC and colors and shapes (don't ask... my daughter loves this game and if I can get her into some retro DOS gaming I will)
I will set up some more tonight, needless to say my BIOS seems to be working good actually it's something in the registry or that system info application that is confused.
I will be posting a picture of my MB as it does seem to be a good setup (3 PCI, 5 ISA, key board and mouse PS2, Socket 3). The only thing I don't see is a hookup for a turbo switch. I do not see a pin connector for a battery besides the Dallas clock.
