First post, by robertmo3
anyone knows if you can buy a pc keyboard with low trapezoid buttons like this one?
https://allegro.pl/oferta/laptop-toshiba-sate … ykaAjBdEALw_wcB
the trapezoid buttons are like normal pc keyboard but they are lower so even better
if you press on the edge of the button they are usually harder to press, but cause toshiba had edges almost in the middle of the button it is always pressed easily
most comfortable buttons i used.
pc keyboards have buttons like that but they are taller so it is still harder to press them on the edge compared with lower buttons
also the trapezoid buttons are so easy to feel, the new buttons are harder to feel where ono buttons ends and where another starts
Toshiba used to have them in their laptops but they later switched to worse like this:
https://allegro.pl/oferta/toshiba-satellite-c … V4aAkgJEALw_wcB
and later to even wose like this:
https://l66.pl/produkt/852867,laptop-toshiba- … ALw_wcB#image-4
only worse i can imagine now would be upside down trapezoid 😉
