Connecting multiple HDD LEDs
First post, by DustyShinigami
Hi
I noticed my new case has up to three HDD LED cables for the front panel, but the manual for the motherboard only mentions connecting one.
The attachment Acrobat_41jAoOSDd9.png is no longer available
The attachment Acrobat_DxqWcTPIrD.png is no longer available
I have this motherboard, by the way - https://theretroweb.com/motherboards/s/abit-ab-be6-ii
I was wondering if it's possible to hook additional LEDs up to this motherboard? I couldn't see anything in the manual to suggest so, but maybe I'm missing something? Or if not, can you get some sort of adaptor for such a thing?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 2 of 30, by Grzyb
How many HDDs you have?
With some HDDs, you can connect a LED to the drive itself, see eg. Seagate ST1156/1133/1111-A :
 Remote LED
A B
+---+---+ Default jumper at C-D for LED mounted on drive PWA
| * | * | To use remote LED, remove jumper and extend B (Anode)
+---+---+ and D (Cathode).
C D
Nie rzucim ziemi, skąd nasz root!
Reply 3 of 30, by DustyShinigami
Shponglefan wrote on 2025-09-03, 12:00:
What case do you have?
Normally cases only have a single HDD LED and consequently motherboards only support a single LED connection as well.
That's the problem - I don't know. ^^; It's some unknown brand. There's no emblem or logo or anything. It was listed as such on eBay.
But yeah, I always figured there was one only. So was surprised to find three.
OS: Windows 98 SE
Reply 4 of 30, by DustyShinigami
Grzyb wrote on 2025-09-03, 12:04:
How many HDDs you have? […]
 Remote LED
A B
C D
Three. And interesting. Had no idea you could do that. Mine only list Cable Mode or Limit alongside Master and Slave. And one is a Samsung.
The attachment IMG_4530.JPG is no longer available
The attachment IMG_4531.JPG is no longer available
OS: Windows 98 SE
Reply 6 of 30, by DustyShinigami
wierd_w wrote on 2025-09-03, 13:09:
Led is / was sometimes found on ide controllers as well.
See for instance, this one, has J1 connector for this.
https://stason.org/TULARC/pc/hard-disk-floppy … IDE-MASTER.html
Now that you mention it, I do recall seeing J1 and J2 in the manual. I'll take a closer look. Thanks. 😀
OS: Windows 98 SE
Reply 7 of 30, by DustyShinigami
Ahh. Unfortunately the cables aren't long enough to reach them. 🙁
OS: Windows 98 SE
Reply 8 of 30, by Shponglefan
DustyShinigami wrote on 2025-09-03, 12:15:
Do you have a picture of the case? I'm curious to see what it looks like.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 9 of 30, by DustyShinigami
Shponglefan wrote on 2025-09-03, 14:49:
Sure.
The attachment IMG_4536.png is no longer available
The attachment IMG_4537.JPG is no longer available
The attachment IMG_4538.JPG is no longer available
OS: Windows 98 SE
Reply 10 of 30, by AncapDude
I would just connect one LED. It May Look weird if three of them Flashing synchroniously. However you can try to connect them in parallel to one Connector, with a little Risk of overcurrent on this circuit. (60mA vs. 20mA, depending on the LEDs)
Reply 11 of 30, by DustyShinigami
AncapDude wrote on 2025-09-03, 15:23:
I mean, I'm sure it would give me a sign if it's overcurrent, right...? But how would one go about connecting them in parallel to one connector? I don't think it would look that weird though. I mean, the LEDs are there on the front, from top to bottom, so it would be great if I could get them working. 😀
OS: Windows 98 SE
Reply 12 of 30, by wierd_w
Or, just make a small driver circuit board.
A 'reapplication' of a level shifter logic circuit would suffice.
Input signal is the motherboard HDD LED pulse.
'level shifted' output is the higher max current supplied with a voltage regulator and the 5v molex connector. (Say, diskette power rail.)
You can drive a shitload of LEDs that way.
Reply 13 of 30, by DustyShinigami
wierd_w wrote on 2025-09-03, 22:27:
Or, just make a small driver circuit board. […]
I have absolutely no idea how to go about doing that or where to even start. ^^;
OS: Windows 98 SE
Reply 14 of 30, by Major Jackyl
It would be fun to use a VU meter type circuit and use the HDD signal as an input. I wonder if that would work properly? It'd look cool if it does.
I have a case that has 10 HDD LEDs and I was wanting to try populating them all, but populating them is hard. Specific cards and drives; ugly, useless combos and such. Really hard to make them all active at once, too. Some circuitry sounds like a good alternative, hadn't considered this before.
The easy solution is to wrap up the unused ones and tuck them away. No monkey-business required*, since they don't have a function. I have 2 Antec Super Lanboys next to me, and they have 3 LEDs (G,R,Y) and only 2 are used, because the computer(s) inside don't offer more than the standard PWR, HDD lights.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 15 of 30, by wierd_w
DustyShinigami wrote on 2025-09-03, 22:43:
A level shifter of this kind needs only be one direction, making it very simple.
You put the HDD LED's input signal on the collector of a transistor, which makes the transistor activate when the HDD LED is energized, and deactivate when it is not. You use a transistor that can handle a larger current flow then the HDD LED header can provide, so that you can drive the parallel HDD LEDs from the signal emitted from that transistor.
See also, here.
https://www.digikey.com/en/blog/logic-level-shifting-basics
Instead of a higher voltage source, you offer a higher current source. (Or, use higher voltage and run the LEDs in series, but meh.)
It's functionally the same kind of thing as a bus transceiver chip, and such a chip could probably be abused here, since we dont really care about isolating voltages, just the amount of charge, and in isolating the LED header from having to deal with so much drain. You can instead use the ground line from the floppy power connector.
Say, one of these 1 bit buffers. You can get 10 of them on a reel of tape for cheap.
https://www.digikey.com/en/products/detail/te … 1G07DCKR/432005
Reply 16 of 30, by DustyShinigami
wierd_w wrote on 2025-09-04, 02:56:
A level shifter of this kind needs only be one direction, making it very simple. […]
See also, here.
Hmm. Would something like that require soldering on though? That's a bit out of my expertise and comfort zone.
OS: Windows 98 SE
Reply 17 of 30, by jmarsh
If you're going to start coming up with circuit ideas or whatever, it might be pertinent to point out IDE activity signals are active low (meaning the LED anode is usually connected to positive voltage and the cathode gets toggled between high/low).
Reply 18 of 30, by wierd_w
getting signals from the IDE ribbon would let you know which specific devices are getting activity... but would require significantly more logic.
You would need to grab when the bus was busy, then also query the value of the cable select line to determine which of the devices was talking, and use an OR gate to get two discrete signals, then drive those with buffers.
You'd need a circuit board for each IDE cable.
The project I suggested would just drive multiple LEDs from a single logical signal, by providing them with the extra current they need.
A simple driver attached to the motherboard HDD activity LED header is all that would be needed, plus a molex power terminal, and a voltage controller IC. All that could easily fit on a 1" protoboard.
Reply 19 of 30, by Disruptor
30 Years ago I connected the HDD LED to the IDE onboard controller and the turbo LED to my SCSI controller.
