Syquest 44MB unit -
First post, by Nexxen
Hello all!
I bought this new toy that I didn't really know how to use and/or make it work. Model name is SQ555.
At first I had some difficulties making it work but in the end I managed to sort it out.
I found the manual online (Atari forums thanks; also available on Archive()org) - see attachment.
It gives all the required information as a stand-alone drive.
My first mistake was to fire it up without proper "termination", here the behaviour:
Windows 98 detects the drive but fails to read it, "no disk inserted" error. Green LED is solid, indicating that the unit has no issue with the disk.
The red LED flashes from time to time (only in Windows, when only hooked to PSU it doesn't)
"Format" command recognizes the size correctly (41MB), but fails with "short foram" with "no disk in the unit";
with "full" fails with "no disk or damaged": either way it just doesn't spin like any disk before issuing the fail message.
The unit requires a resistor network (8-pin 5*221/331G; 220 ohms) (see pic Re: Bought these (retro) hardware today).
Properly terminated it works wonders. I plugged a CD-ROM, having termination switched by a jumper, as last device on the chain to achieve that.
(to any SCSI user this is basic knowledge with a facepalm 😀).
Test:
1) R/W was difficult initially, after formatting in Windows (like any other disk) I performed a full surface Scandisk with error repair: disk works perfectly but 256KB appear as bad sectors; it took 5 hours with huge legs on bad sectors zones (75% was done in like 10-15 minutes).
2) Using OS X 10.4 it's trickier: initialisation isn't effective as in Windows. Repair wouldn't really do anything. R/W was slow and painful on bad sectors. (probably I should have used the PLI program that was on the disk to format - OS 9 or earlier version by the icons).
3) speed is not bad, 41MB were copied in less than a minute (I didn't clock it, just looked my watch). I didn't do a full test with a specific program.
Well, this is my little banal experience with this historical relic.
Some YT links:
https://www.youtube.com/watch?v=kYQWgHE-G84 (short)
https://www.youtube.com/watch?v=NVpcN0PjEJQ (short)
https://www.youtube.com/watch?v=zJT_lXUPIu0 (connected to an iPhone)
https://www.youtube.com/watch?v=211-eHVkqeo (not 44 but nice history review)
Drivers and stuff:
https://web.archive.org/web/20030218161807/ht … st/syquest.html
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 2, by Nexxen
Pics:
The resistance network for the unit should come with a plug-in selector, and I'm wondering if it is the one located on the adapter to centronics socket.
Reply 2 of 2, by Nexxen
I got a new batch of disks and wanted to test them.
My usual tool is Win98SE surface test.
Results:
1. some disks have R/W issues and display 43.164 clusters (close to total space on disk IDK), 44.199.936 bytes or less (chkdsk show bad sectors).
Problems are at the beginning and the end of the test; test like makes my PC unusable, still responsive with a huge delay. It completes the task.
W2K works ok but disks are still bad.
2. the working disks show 20942 clusters,
No problem in any way, R/W. Works well in every setting.
I don't get the difference in clusters reported by Win98.
Win2K CHKDSK reports:
1. 40K clusters disks: 85334 units for 512 byte each (FAT)
2. 20K clusters disks: 20942 x 2048 byte (FAT) - 42.889.219 byte
How can I format forcing 2048?
512 byte should be just fine for 44MB.
Btw, Writing to disk takes some time, 0.5-0.7 MB/s. Smaller and lots of small files will have an influence. Few, large write faster (steady).
Reading is lightning fast, range 15-20mb/s or close, to a ATA133 disk.
This is for future reference.
