First post, by H3nrik V!
- l33t
So, I have an ABiT BP6, which I was gonna do an "unlimited (for it's time) power" build, as in fully loaded with 3x256 MiB memory and the fastest CPUs available.
Running for years back in the day with a couple of 366s at 550, I figured that 600 was doable with some 400s, so I bougt a total of 9 specimens ..
Running a test rig with an ABiT BH6 1.01, 2x256 MiB PC133 and a Gigabyte GA6R7 slotket with an Alpha PEP66 cooler on, I started binning.
But utter lemons. Out of 9 CPUs, 3 couldn't run a full memtest86 (Yes, I had tested the memory using a 100 MHz FSB CPU beforehand), 2 couldn't even execute memtest86 and the last 4 didn't even POST at 600.
Voltage was tried all the way up to 2.3V - I even fiddled with L2 Cache latency for at least one of the CPUs, but to no avail.
Is it just so, that 550 is how far the architecture scales, or did someone have more luck?
