unknown ISA 16 bit card
First post, by mbx
Hallo guys,
I have found 16 bit ISA card in a 386sx-20 I cannot recognize. The card has an leaked battery, BIOS (probably) 27C256 with a badge MICROBASE INC., SER: M1 00995, one 74LS245H, HY6264LP-10 , PAL20L8ACNS and 2 unknown DIP 20 (with traces of brushing or polishing). The card holds no printings except a date 91/33 and something like a logo (3 concentric circles, 2 outer ones are connected at opposite points). There is also nothing bellow the paper badge (Warranty void...) - I removed it and checked. Does anybody have any idea about the card? Thanks...
Reply 2 of 8, by jmarsh
Yep. HY6264LP-10 is an SRAM just like the ones used in old console cartridges, the "LP" stands for low power to avoid running the battery down quickly.
Reply 3 of 8, by mbx
I have similar feeling - something like that... What I have found - contains just memory and bus controller... But the original computer is working without this card and there is a battery on the mainboard as well. It is Philips 5107-200-36154 386sx-20 motherboard. But... It still beeps an error (FDD) during setup. I suppose that the integrated controller is gone and want to connect fdd to some ISA controller (not yet tested...).
I have no idea about its purpose...
Reply 4 of 8, by georgel
You'd better dump and post here the BIOS extension from DOS and then it can be told with more certainty. For now it looks to me like a BIOS extension that saves its setup in the SRAM, most likely could be a BIOS extension for larger hard drives.
Reply 5 of 8, by jakethompson1
Any possibility it's a licensing dongle but as an entire card?
Reply 6 of 8, by mkarcher
jakethompson1 wrote on 2025-09-05, 22:42:
Anything is possible with licensing dongles, but I would hope most licensing dongles used serial EEPROM instead of battery-backed SRAM for license information, if that information needs to be modified after the dongle is deployed. Furthermore, if the licensing information is in the SRAM, there would be no need to have a ROM on the card as well. And if the licensing information is in the ROM, why would you deal with the hassle of implementing a battery-backup solution (with a leaky NiCd battery, leakage damage is clearly visible on the photo).
Reply 7 of 8, by jmarsh
It's definitely possible, there were arcade machines that were purposefully designed to store their graphics data on battery-powered SRAM. When the battery went flat, no more sprites...
(Did I mention the battery was epoxied to the chip, enclosing/hiding its existence?)
Reply 8 of 8, by mbx
georgel wrote on 2025-09-05, 21:44:
thanks. can you give an advice, what sw to use? i dont have experince with this...
