First post, by 5a796d
I have a Chaintech GeForce FX5200, 128MB, 64 Bit AGP (A-FX20-D128DN-V87S) that I would like to transform into FX5500, could you tell me where to find the right bios?
Reply 1 of 2, by NitroX infinity
It's just a 20MHz speed difference. Why not overclock it?
Also, the 5200 came with either a 64bit bus or a 128bit bus while the 5500 only had a 128bit bus.
Reply 2 of 2, by 5a796d
NitroX infinity wrote on 2025-09-06, 19:27:
I read that the 5500 were also 64 bit.
I thought the frequencies were clearly greater but if you only tell me 20mHz then I try overclocking. Thank you
