First post, by Stretch
Stretch
Offline
A couple of years ago I learned enough assembler to convert a MS-DOS Lemmings Music Player to Mortal Kombat 1.
The timing uses BIOS Wait int 15h ah=86h, which only seems to work properly with DOSBox.
Can you point me to a resource for converting int 15h ah=86h to a ISR? I seem to recall that a ISR has more accurate timing but I haven't studied in a long time so I forgot most of what I learned.
EDIT: Swapped TSR to ISR.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
