First post, by DustyShinigami
- Oldbie
I'm having a problem getting the Seagate Tools for DOS working under, well, DOS. This was never a problem with my previous motherboard and setup. I ended up reformatting my E drive after it was complaining about errors and bad sectors again, and ended up using FDISK. That, in turn, adjusted the capacity of the drive from 80 gig to 30. So I need to use the Seagate Tool to set the right capacity again.
I originally burnt the ISO to a CD, but when I put the disc in, it starts to initialise, and says 'Starting BCDW... ok.' but then does nothing. On a couple of occasions it complains by saying 'Read error. Press any key to reboot'. I tried looking online, went to the website that has the tools, and there was mention of the legacy version. However, trying to download any of them just gives me this screen:
I did manage to find them on the Internal Archive, but I've tried re-burning it again, but still get the same issue, and I've tried the text-only version, which is 1.12, and the same thing happens. 🙁
I'm not sure what the issue is or why. Any suggestions? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
