Stability and idiot-proofness. Intel mainly sold to OEMs and they wanted trouble-free operation. Given there are only four interrupt lines on the PCI bus and despite spec saying cards should play nice and share if needed, a lot of cards don't. So on boards with 5 or particularly 6 PCI slots you frequently had to juggle cards around to find which cards really didn't like to play nice (usual suspects: SBLive, add-in IDE/SATA, TV cards etc) and which slots were unshared. Not a major chore if you know what you're doing and why, but if you don't and assume all PCI slots are equal, you can get into a bad frustrating mess which Intel's customers don't want.
Of course PCI shares with AGP and with integrated I/O as well, plus the BX-6 shown in comparison also only has 4 PCI slots, so that's not the difference here. The other difference is clearance around the CPU slot. By not using the top external slot position, Intel allows for more distance between AGP and CPU, and between CPU and top of case. That not only allows easier CPU installation, but also allows OEMs to use creative shrouded cooling solutions that wouldn't fit if crammed in. IIRC Dell, who used the SE440BX, used something like that.
