First post, by hornet1990
Hi
I've got a Diamond S540 Savage4 pro card (32mb) that I've put in my pc to do some tests but for some reason when you run anything 3D using Metal (S3 Angel tech demo) or DirectX (3DMark 99) after a number of seconds it freezes and locks the PC up (doesn't respond to power button, but does the reset).
Interestingly the amount of time it can run varies - when the machine was well warmed up it would be just a few seconds before freezing, but from cold and with a fan blowing on the card it is more like 30 seconds. When it is running there is no obvious visual corruption in the demos and they appear to function normally.
I've tried different S3 drivers but they all behave the same. 2D appears fine, it only seems to be a 3D problem. This is also on a completely fresh Windows98SE installation with just chipset (v4.27) and VGA drivers installed.
The same system with a PCI Voodoo4 instead works perfectly fine for everything.
I tried running Video Memory Stress Test CE 1.21 on Hirems BCD and that threw hundreds of thousands of "Error at [address] must be 00, but found FF [bits:11111111]" errors before I just gave up the run after over an hour. If the memory really was corrupted that should've presented during the longer runs (and in 2D).
The system specs:
AthlonXP-M with 5x multiplier - fsb at 100 for 500mhz or 200 for 1GHz - issue occurs at both speeds (S3 Angel was noticibly too fast at 1GHz too)
Chaintech 7NJL3 nforce 2 400, all on board devices except IDE disabled (Serial, parallel, audio, lan etc)
Cruicial 64GB SSD via Startech IDE-SATA adapter
All three 4x AGP jumpers set on the S540
8x AGP disabled in BIOS, 64MB apeture, issue occurs with fast writes enabled or disabled.
Any thought's on what else to try/look at? The only other thought right now is to try another AGP card to see if that behaves, which might rule out an AGP problem?
Thanks
https://rogueone.uk Kyro and other things
Reply 1 of 17, by Putas
Can you run the AGP texturing test of dxdiag?
Reply 2 of 17, by Linoleum
Isn't the Savage4 an AGP 3.3v while your board is an AGP 1.5v? In other words, this board might be too modern for the card...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 3 of 17, by hornet1990
Putas wrote on 2025-09-12, 12:13:
There isn't one (I've got Dx7a installed) but the DirectDraw and Direct3D tests both pass. Disabling the AGP support does nothing - it still freezes.
Reply 4 of 17, by hornet1990
Linoleum wrote on 2025-09-12, 16:29:
I saw that some Savage4's were 3.3v but assumed as it had 4x jumpers and universal cutouts it would be happy with 1.5V in a newer board but you're possibly right. I have been eyeing up an older 1x-4x AGP SocketA motherboard so I might have to bite.
Reply 5 of 17, by Linoleum
hornet1990 wrote on 2025-09-12, 16:51:
I have a Savage4 that was running well only on a PII board... Anything else would behave just like what you are describing.
Based on the few info I could find, many Savage4 are indeed AGP 3.3V cards. I.e: https://theretroweb.com/expansioncards/s/teppro-s3-savage-4
While your motherboard is definitely AGP 1.5V only: https://theretroweb.com/motherboards/s/chaintech-ct-7njl3
Reply 6 of 17, by shevalier
This doesn't affect anything at all.
1.5/3.3V AGP is the interface supply voltage.
If there was a mismatch, then either something would burn out, or the video card would not be detected.
The problem may be different, namely, in the power supply of the video memory.
SDRAM has a supply voltage of 3.3 V.
Therefore, it can be powered either from a regulator with +5 V on the video card itself (more modern and advanced designs), or directly from the motherboard (from the power supply).
If, due to an unsuccessful combination of the motherboard and power supply, the video memory receives a voltage of 3–3.1 V, then it may begin to fail.
On old motherboards, where 3.3 V was often regulated locally, for example, all sorts of 440BX/MVP3, you can install, for example, 3.5 V.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 7 of 17, by hornet1990
shevalier wrote on 2025-09-13, 03:59:
The problem may be different, namely, in the power supply of the video memory. SDRAM has a supply voltage of 3.3 V. Therefore, i […]
I have just replaced the PSU with a "newer" (circa 2009/2010) 500W PSU as the original 300W was causing random restarts. It is a slightly lower rating on the 5W and 3.3W rails - 150W, 25A on both, compared to the old which was 180W, 30A, 28A respectively. But the system is hardly being stretched with the little hardware that is in it.
Is there an easy way to check the voltage getting to the card? (I can use a multimeter but I'm no expert and mostly use it for continuity or testing for AC mains voltage)
Reply 8 of 17, by Linoleum
Let's settle that 1.5v vs 3.3v question... Based on this info here https://www.playtool.com/pages/agpcompat/agp.html what AGP voltage slot does your card has?
Reply 9 of 17, by shevalier
Linoleum wrote on 2025-09-13, 13:41:
If you read your own link carefully, it says that 1.5V/3.3V is the power supply for the AGP INTERFACE of chipset and video card.
If the BIOS has detected the video card and it has started displaying the image, then the matching of signal levels and interface speed from the motherboard and the video card has already been completed successfully.
hornet1990 wrote on 2025-09-13, 09:49:
Show a photo of the videocard.
Well, and measure the voltage between the orange wire (+3.3 V) and the computer case on the switched-on computer.
PS. https://docs.rs-online.com/8f7f/0900766b8002c872.pdf
Reply 10 of 17, by hornet1990
shevalier wrote on 2025-09-13, 14:57:
Voltage on pin 11 (the only one I could access) is 3.39V.
Here's the card, with the 3 jumpers set as per the docs (as they have been since I put it in):
The attachment IMG_7714.jpg is no longer available
The attachment IMG_7715.jpg is no longer available
Reply 11 of 17, by shevalier
hornet1990 wrote on 2025-09-13, 18:18:
Excellent voltages.
Then either there is some local incompatibility and you need to try a much older motherboard, such as VIA 694 or Intel 815/440BX.
Or really serious problems with the video card memory.
Reply 12 of 17, by arnovdheiden
You could try to use some less old chipset drivers. I think 4.43 for your system is better suited.. It has some agp improvents which might solve the issue
Reply 13 of 17, by hornet1990
arnovdheiden wrote on 2025-09-14, 07:01:
I’ve not found any nforce drivers for 9x higher than v4.27 - I think they were the last to support 9x. Are you thinking of Via drivers?
shevalier wrote on 2025-09-14, 04:23:
Excellent voltages.
Yeah, I'm starting to think that might be necessary for these older cards.
I have tried using S3tweak and underclocking the memory and core but it made no difference. Interestingly in S3tweak if I try to access the AGP options it also locks the machine up...
To try and rule out an AGP problem I reinstalled windows and used the older nForce v3.xx drivers but no difference. Then I removed the savage and cleaned up the driver and then put my TNT2 Pro in with nVidias 45.23 drivers - the card again works in 2D but 3D flat out fails - even the dxdiag direct3D test fails to run (directdraw fine), but at least it doesn't crash the machine. I then swapped in a GeForce MX440 8x which has artefact issues but mostly "works" and that was fine, the 3D worked.
I'm suspecting this board just doesn't like the older DX6 era cards even though they are all 4x. The only other card I have to hand at the moment is an ATI Rage Pro 128 but there doesn't seem much point trying that. I do have an Asus K7S333 board on its way to me which is 1x to 4x so I'll try the cards with that if its working ok. Otherwise I will have to look at something more era appropriate for the cards.
Thanks
Reply 14 of 17, by arnovdheiden
hornet1990 wrote on 2025-09-15, 08:20:
I’ve not found any nforce drivers for 9x higher than v4.27 - I think they were the last to support 9x. Are you thinking of Via d […]
Excellent voltages.
Thanks
Yes i was. Sorry.. I was facing similar issues with my via mvp3 system and savage4 pro.. Wrong assumption that your system was also via based 😅
Reply 15 of 17, by Putas
Next, I would try underclocking and check settings with a utility like PowerStrip; perhaps there will be a sensitive setting that can be disabled.
Reply 16 of 17, by hornet1990
Just a quick update.
I received the Asus A7S333 motherboard which is only 1-4x AGP (the Chaintech was 4x & 8x), popped an 1800+ t'bird in and with 4x set in the bios and on the card the same locking up still happens. However dropping the bios to 2x and removing the jumpers on the card the S3 Angel demo runs fine, all the way through no issues.
Clearly the card isn't happy about something relating to 4x AGP.
The nVidia TNT2 is still toast in 3d, but that'll probably be the subject of another thread...
Thank you for all the help and suggestions.
Reply 17 of 17, by Linoleum
hornet1990 wrote on 2025-09-20, 13:31:
Just a quick update. […]
Great to see you got it up and running! I had a lot of fun tweaking games for this card myself. I came across several posts—both here and on other forums—confirming that the Asus A7S333 does support both 1.5V and 3.3V AGP cards. I had a feeling this was the issue...
